New Ultrasonic Machine Raises Eyebrows
ddk
6,261
4,043
995
Utah
Yes, LAST sounds different, as I said, it has less grove noise. Good, bad? I dunno, really don't care. It won't stop me from buying an a used LP, but I won't buy the treatment either.
David, the problem with "really dirty" LP's typically isn't that you haven't got it clean, it's that the sounds you're probably still hearing are from cavities in the vinyl - not bumps of dust. The cleaners can't help with that sadly. That's why even a good cleaning that sounds a lot better will still have some noises.
Maybe that too but for the most part the fungus, dirt, whatever is still there even after 4-5 cycles.
david
pcosta
368
124
1,600
Windsor, Ontario, Canada
david
Which ultra sonic machine do you use. I am only asking as I would like one but haven't decided on which one I want. I certainly like the less hands on maintenance of the KL over the Audio Desk.
ddk
6,261
4,043
995
Utah
The one in my signature :)!
david
pcosta
368
124
1,600
david
It appears as if the earlier reliability issues have been solved as I don't see anyone complaining anymore. I have friends with the KL and some with the Audio Desk and everyone is happy with their decision on the machines they chose.
ddk
6,261
4,043
995
Utah
I haven’t had any problems with them.
david
pcosta
368
124
1,600
david
Seems like it a mixed bag with both. I am tempted to go the DIY route, but I know deep down I will not be very enthusiastic about cleaning records that way. So for me the AD or KL would be the way to go, but the prices!
ddk
6,261
4,043
995
Utah
Call me.
david
spiritofmusic
14,626
5,435
1,278
E. England
Pcosta, do look at the Degritter thread I’ve started.
I’m absolutely thrilled w this machine, whether it’s coincidence or not w my newly optimised analog install, my vinyl has never sounds better.
Mike Lavigne
Apr 25, 2010
12,601
11,693
4,410
david
Keith Monks = Loricraft PRC4
the Loricraft is a less expensive version of the Keith Monks.
I've owned 3 Audio Desk RCM's, 2 Loricraft PRC4's, and 1 KL.
if you commonly buy nasty used records and need deep cleaning the Loricraft/Keith Monks is best. but requires lots more focused time, chemicals, and effort.
if you are cleaning or touching up already pretty clean records and like to listen and not futz then get a KL. you can listen and clean at the same time. I now only use this one. at one point I had all three of these together.
if you are a dice roller get an Audio Desk. it combines friction cleaning and ultrasonic. but it's got lots of moving parts. the newest ones are much more reliable.
bonzo75
22,646
13,677
2,710
London
Pb Blimp
518
25
140
USA
http://www.keithmonks-rcm.co.uk/][ulr=Keith Monks[/url] = http://www.garrard501.com/prc2.html]
if you are a dice roller get a Audio Desk.
I am a dice roller but I gotta have some upside. I own the KL. Couldn't be happier.
ddk
6,261
4,043
995
Utah
Which do you prefer, volume aside?
Keith Monks. Mike has the same experience, flossers clean deeper and in my case I don't bother cleaning records that are eye clean unless there's surface noise.
david
spiritofmusic
14,626
5,435
1,278
E. England
I’ve directly compared my Loricraft v beta tester Degritter.
No contest, either dug in dirt, or superficial, the Degritter is best.
And not by a small margin.
slowGEEZR
1,322
79
968
72
Colorado Springs, CO
Well, back then people were unaware of many things and used chemicals to clean their styli too destroying the cartridge’s suspension in the process. Many of this only became known years later. I never used LAST myself so I don’t know how it went on just what it looks like now.
david
I've used LAST for many years and have noticed no ill effects. None. I've inspected the needle after playing. Nothing. That others have an issue is beyond me.
Reactions: stereonut8
DaveyF
6,129
181
458
La Jolla, Calif USA
Steve, IF the original application of LAST was haphazardly applied, and way way too much of the LAST was used, I can easily see how the results that DDK report could accrue.
ddk
6,261
4,043
995
Utah
At least on paper the Degritter looks like the better widget than the ones I tried but I still believe that manual cleaning is the way to go with heavy soiled records.
david
Audiophile Bill
4,293
4,093
675
I have to say for right or wrong, I am tempted to acquire one of these because it is so cheap at $850 AND because I can’t clean 7” and 10” on my existing Audio Desk.
Folsom
6,030
1,503
550
Eastern WA
david
If you have records that bad you probably need to add a little hepastat. If that still doesn't work you need something that can break down a biofilm. In that case you need enzymes with it. I am not certain where to buy enzymes on their own. Pomegranite juice would work but I don't know how problematic rinsing it and the sugars would be - I would test it first. I suspect if its easy to clean off then you could spread it on the disc and let it sit for a few minutes before cleaning with your iso, hepastat, & surfracant mix in the sonic machine.
spiritofmusic
14,626
5,435
1,278
E. England
Bill, too bad you didn’t get on board w the Degritter beta testing program, you’d have a machine that can do 7”, 10” and 12” discs for c£1k.
4,702
Yes, there are many of threads in audio forums with people expressing divergent opinions. Anyway LAST is now a product that is almost (or over, perhaps) forty years old, and its formulation has changed more than once since it was introduced - even by safety and ecological reasons. My experience dates from early 90's.
