Hi,After 2--3 month of playing/burn-in i hear a significant improvement in SQ.
I'm using a generic power cable cause it sounded most natural to my ears.
Any positive reports on other power cables?
Yes , I have prefered AR ethernet cabledo you think the Weiss can benefit from an "audiophile" Ethernet cable like?
Hi Amir,I have used this configuration:
iMac 27" core i9 (highest CPU/RAM) + Roon
Apple Time Capsule as Switch
Weiss DAC501 (Roon Ready)
Vitus SIA-025 Class A Zero Feedback Amplifier
TAD CE1 Loudspeaker
we had 4 different ethernet cables:
Legrand Ethernet Cable
China Made Noname Cable
Purist Audio Ethernet Cable
Acoustic Revive Ethernet Cable
all AC cables were Purist Audio Neptune
No AC filter , No AC Conditioner in the Line
No Ground Conditioner
No Audiophile Rack , All placed on Natural Wood
IC and Speaker Cables were Skogrand
No wifi , All connections were Ethernet Cables
Roon Core optimized by sudo renice linux command
Weiss 501 Output voltage around 6.8v (0db)
Vitus input Voltage adjusted on 8v
Signal Polarity was Correct
AC Polarity was Correct (both Vitus and Weiss sound better at Correct AC Polarity)
Speaker position was good
Room RT was good
Room size was smaller than 28sqm
Main AC Quality was good enough
All equipments were fully breaked-in
we repeated the test more than three times and even in blind test the difference was obvious .
Three young audiophile listened to this test.
the sound of Ethernet cables were not equal
The DAC502 is transparent enough to show the differences between LAN cables. I currently use the Sablon Audio Ethernet cable (pre 2020 version) and have compared it directly with the Telegartner MFP8 GOLD IE Ethernet Cable.do you think the Weiss can benefit from an "audiophile" Ethernet cable like?
I also find positive comments about Melco Audio.The DAC502 is transparent enough to show the differences between LAN cables. I currently use the Sablon Audio Ethernet cable (pre 2020 version) and have compared it directly with the Telegartner MFP8 GOLD IE Ethernet Cable.
The Weiss is fed by a Melco N1ZH/2EX-H60 60 EX, which is connected to a Buffalo BS-GS2016A (modified and used with a Plixir DC LPS) which, in turn, connected to a Cisco 2960, then the router. Have bought the Ediscreation Silent Switch OXCO so may try that between the Melco and the Weiss (as recommended by Edison, the maker).
In the above setup,, there were differences but not night and day, and may be a matter of preference perhaps as to which is better. Planning to try the Acoustic Revive LAN-1.0 Triple C ethernet at some stage.
P.S.: also don't forget: Weiss DAC doesn't stream directly, it is acting as a roon bridge or UPNP device. Therefore high-grade Ethernet have less more impact, than from where your streaming source comes (roon/laptop ...)
I meant the Weiss is an Roon-ready/UpnP streamer only, no Tidal, Quobuz or Spotify connect is embedded.Could you clarify this statement? What is meant by "doesn't stream directly"? Is it any different from using a Raspberry Pi or any other device as a streamer?
I am using Roon on a laptop. The laptop is directly connected via an ethernet cable to a DAC502, with a Pink Faun LAN isolator in between (no switches, routers, etc). Now using the Weiss' Roon Ready mode to play audio from Roon.
In this setup, I assume it is the Weiss that is acting as the streamer and not the laptop? Which is to say, the quality of the laptop & quality of power to the laptop, etc., should not matter to the sound? Or would I benefit from instead connecting the laptop via ethernet to (for example) a Raspberry Pi running Ropieee, and then connect the Pi to the Weiss via USB?
Your setup is fine, use your roon on any device you've and the Weiss as endpoint.
I'd never user an Laptop USB attached to a higher quality DAC, because those are cheap consumer chipsets.
Devices like Anitpodes, Jcat do have quality audio-tuned USB, but at the end, for me is LAN and Roon endpoint the better way.
I personally don't stream via Roon, instead using Lumin mini U2 as streamer, attached via AES/EBU to the Weiss.
You'll be another happy Weiss-owner ;-)I’ve read through all of the pages dedicated to the dac50x. My 4ch 501 is supposed to come in tomorrow and I’m genuinely excited. Took a bit of a gamble because I wasn’t able to demo but if it surpasses my current dac I’ll be ecstatic. I’m still trying to optimize my rack so there’s constant tweaks going on so hopefully that won’t throw me off.
