Oops, could not tell that was vdc... Still without impedance values it is meaningless.
Instantaneous current response, again, is pretty worthless measurement. Almost no devices are limiting on that. The problem is that one device will recover well, and another will not, from the loads on the line. When they recover poorly the complex impedance goes all waahooey. When that is going on, what you hear is what sounds like a loss of current.
I've demonstrated that even with a large - absolutely in excess ampere - transformer will still exhibits the same problems a moderately "appropriately sized" one does. They may sound different, but right/wrong from a measurement perspective isn't probably going to give you any appreciable discerning. A moderately sized one would work better were it to have forms of correction, than a larger one. But distances from equipment matter. It's problematic to try and help a transformer when they're too close to the gear. Their seemingly low Z will trump attempts to fix the issues, but the reality is all your equipment is suffering from a big loop of complex impedance disruption. BTW I've heard smaller ones sound better on occasion. Bigger is better is relative depending on some factors. Frankly almost no audiophiles can properly identify what a lack of current sounds like. I haven't met one yet. They recognize sound patterns they assume are a lack of current, but they are usually something else. There may be consistent parallel changes, but that still doesn't explicitly say "current sounds like this". (because usually it has nothing to do with what people think)
And there is no reason not to use capacitors, unless you're using them incorrectly. When used poorly they HELP circulate more noise. Sadly I see them everywhere doing just that. People have no idea what they're doing with them, is my basic conclusion in the AC realm of audiophile products. They can also encourage Eringing when used incorrectly, which can lead to loss of actual available current.
Philosophy can't win, not in the AC realm. Nor can best wishes. It's a game of best engineering in an environment more complex than anyone gives it credit for... one that has effects people will judge it for inappropriately due to their own lack of knowledge. In the AC realm a mature understanding is that actual attenuation numbers mean little compared to actual performance; higher is better but it has a clause where several other variables are necessary. It's a realm of lies and deception for attenuation numbers, too, because most of the numbers and graphs you see are utterly unrealistic, favorable, conditions that were used for measuring.
