Everyone should pay attention to the new QSA Lanedri line of products being discussed here: https://www.whatsbestforum.com/threads/qsa-lanedri-series.36078/
I’m going for the moment at least back off my comments….
In the past, I have been a fan of all of the SR fuses. I then went to the QSA yellow fuses. I did not try the SR purple. I had them in all of my components. However, since the end of last year, I have added the Lampizator Horizon, DAC, and Aries Cerat Essentia monoblocks. Curiously, I did not add any boutique fuses to my recent additions.
I had an SR Power One filter plugged into the end of my Inakuatic 3500P Power conditioner to the SR Orange wall outlet. My power cord is the Hijiri Takumi.
I debated whether I would add the boutique fuses to the AC amps and the Horizon. They take 6 and I was thinking about the QSA red or red black. Mike at Tweek Geeks suggested I try the QSA Conditioner plugs instead.
I removed the SR power one filter and installed a QSA Silver conditioner jitter plug. I turned my system on and listened to music with my head down reading articles on my computer. About one minute into the first song the change in SQ immediately struck me. I looked up and began to focus on the music and what
I was hearing. The music was crystal clear. Each instrument was very detailed. The vocals were succinct. The soundstage widened. Even the bass was better.
I now listen to more jazz and instrumental pieces because the orchestration is so good. I am even hearing tiny background instruments that I had never heard before.
I have no idea what QSA does to this cheap-looking plug but for me, it works. I probably am done buying fuses. But I do wonder what would happen if I replaced my SR Orange outlet with a QSA outlet.
This "QSA Silver conditioner jitter plug" is essentially the wall plug portion of a power cord. Imagine what happens when the same QSA treatment is applied to the entire power cord.
Please report back your results.This is exactly what I was thinking when considering the investment.
I ordered QSA Lanedri top powercord ( Ultimatum ) with Infinity treatment
and I plan to use it as a main cord for the sockect splitter ( Thinking Shunyata everest ? )
so every component in my system can benefit from this preformance.
The splitter/distributor/line conditioner will have an influence. Basically any untreated device that you put into your chain will somewhat mute the impact of any QSA-treated device that is upstream and yet the impact can still be very significant and worthwhile as evidenced by @Willgolf's experience with a QSA Jitter plug. In this situation, if you can replace the outlets in your "socket splitter" with QSA-treated outlets, as you might imagine, there will be significant gains to be had and these gains will be additive to any Jitter plugs or QSA-treated power cables you may already be using.will do for sure.
Just not sure what top performing solutions are recommended for the Socket splitter.
Need to plug all things like DAC , pre, server, 3 power supplys to one device that will be connected to the wall by Ultimatum Infinity.
My worry was that splitter can infuence the Ultimatum performance .
I hope I am wrong , and there is no infuence on the Ultimatum power cord performance .
If anyone is looking to find a good value on a QSA Silver fuse, I have one for sale. Perfect size for Taiko Extreme (6.3A - 250V). PM me.
The Extreme is 4 amps.Are you sure you use 6.3 A ?
The original is 2A/250v
This is a big difference.
For clarityThe Extreme is 4 amps.
The 6.3/250 is good for US 120v on the Extreme.For clarity
4A/250. for 120 v (US)
2A/250v for 240v (EU)
as Emile mentioned,
And this is exactly what I got with my extreme,
Nice carpet !I'll share my experience with QSA fuses. I've played around with fuses over the years, enough to know they can make a difference. I've tried a variety of inexpensive fuses from the likes of Bussman and Schurter. Yeah, they get the job done but that's about it. I've tried fuses from HiFi Tuning, Audio Magic (including the Beeswax SHD), and the full range of the SR fuses including their new Purple fuse. It was with SR's Orange fuse that I felt the fuse became a necessity. Before that, it was more I could take it or leave it. But even with the SR Orange, the improvement wasn't huge. It was a tweak level improvement that was worth its asking price of $150. If there is a downside to SR fuses, they are prone to blowing and I've blown 6-7 of these fuses over the years.
I decided to try a QSA fuse after reading about how their $28 entry level fuse was performing about as well as the SR Orange fuse. Yes, I saw QSA was also selling a Silver fuse for $5000 USD (the $10,000 Gold fuse is not yet available) and I said to myself there was no way I'd ever buy a Silver fuse but I took the chance on a Red fuse for my preamp (which has a soft start) and this fuse retails for $1422. These fuses can be purchased here in the U.S. through tweekgeek.com and Mike Garner, the owner, is excellent to deal with but the Red fuses are special order and so I went straight to QSA in Hong Kong and they had the fuse in stock. I wired them the necessary funds and I received the fuse here in California after about 5 days. The Red fuse came with a 30-day satisfaction guarantee. Their warranty also indicates they will replace a blown fuse up to 3 times within the first 2 years after purchase.
To cut to the chase, this Red fuse is amazing. It isn't just a little better than the SR Orange, it is a Grand Canyon chasm like difference. Yes, the ground floor drops but the presentation is livelier and more dynamic. Bass is more plentiful, cleaner, tighter, and better defined. Vocals have more presence. Treble is more refined. But ultimately, what was so good is how natural everything sounds. You can play louder without strain or fatigue and you can listen at whisper volumes because there's so much more presence. After a week, I had enough. I went back to QSA and asked to send back this fuse in exchange for a Silver fuse and so I did what I said I would never do. I also ordered a Red fuse specifically for my SGM Extreme. QSA makes fuses expressly for digital gear that is designed to address HF noise better and so obviously, these fuses are intentionally filtering. I already knew this because I have bypassed fuses before and I know what that sounds like. The improvement in SQ from a Red fuse was far greater than what I have heard by bypassing a fuse.
The Silver analog fuse (for my preamp) and the Red digital fuse (for my SGM Extreme) arrived 3 days ago:
Yeah, I'm a crazy lunatic for spending this much money on fuses but I'm a happy crazy lunatic. As good as the Red fuse is, the Silver fuse is just better and not by a small margin. It does all the things a Red fuse does but takes it up several notches. The clarity over the Red fuse is just unbelievable. More space, images have greater density (but not at the expense of speed or agility), and unreal transient response. The presentation sounds more relaxed but the Silver fuse is capable of explosiveness that the Red fuse can't match. Supposedly, the Red fuse takes 2 days to burn in while the Silver fuse takes 7-10 days but at day 3, the combo of Red in the Extreme and Silver in my preamp is really as good as I could hope for. There's no way these fuses will be returned.
I have tried the Silver in both a Vinnie Rossi L2 preamp with Takatsuki 300B tubes and a D'Agostino Momentum HD and with either preamp, the jump in SQ is beyond what I'm getting from anything else I've tried with either of these preamps. To go from the stock Electro Harmonix 300Bs to the Takatsukis is a nice jump in SQ but not as big as the improvement gained from an SR Orange to the QSA Silver fuse. The improvement gained from the stock footers on the Extreme to a quad of CS2 1.5 footers is a nice gain but is not as big as what I'm hearing from just the Red fuse. Not really even close. I'm evaluating a $9k Shunyata Omega QR power cord for the preamp and the gain over an inexpensive $200 TG SLVR power cord is nowhere near as substantial as what I'm hearing from the Silver fuse. I'm currently evaluating the new Synergistic Research SX Ground block with a full loom of SX ground cables:
The impact of completely grounding my entire system with this >$10k ground block + cables is substantial but the impact of a single QSA fuse is still greater.
If you're the kind of audiophile who is open to spending $10-20K for a power cord, then something like a Silver fuse could make sense, otherwise, QSA makes fuses that start at $28 but having evaluated various power cords over the years including the High Fidelity Cables Pro Series, Nordost Odin 2, and others, I have yet to hear a PC that makes the same difference as this QSA Silver fuse.
I have no affiliation with QSA. They are based in Hong Kong and I am based in the U.S. I have my guesses but I really have no idea what they have done to these fuses. I have no measurements I can offer and I suspect they don't either. Even if they did, I don't think measurements would convey just how large the gap in SQ I'm hearing with these fuses. Yes, these are sacrificial items and eventually, they could blow although they are willing to replace or repair their fuses during the warranty period. You could always choose to uprate the fuse but then you would have to accept the risks that go along with that and so consequently buying a fuse this expensive is not something I can condone but in my case, I already know I will be exchanging this Red fuse I bought for the SGM Extreme and will upgrade it to a Silver.
