congratulations still loving the m3's curious what the differences areI thought it was time
I pulled the trigger on theMK 4 version. Best Buy is offering a free trial until Jan.6. Substantial discount.
BRING ITNow that I am listening to the fourth version of the Sony headphone I think it warrants its' own review.
Now whats the difference between the 3 and the 4 as I believe you are comparing to the 2 correctThe latest version of this headphone is a significant improvement in every significant area.
Prettier.
More comfortable
Better noise suppression
Longer battery life with fast recharge
Most important -better sound quality
SONY continues to improve this device without the benefit of a price increase.
Sound.
I just did not have to listen as loud.
When paired wit the ifi hip-dac the xm4 delivers audiophile quality sound. I was able to grade the relative quality of various recordings.
It has excellent bass. My attention was drawn to the instruments rather than the general perception of bass. I noticed a vast improvement in low level resolution.
There was less noise and distortion. The music had a fullness with air around the instruments.
This is a high -end device that requires adjustment for best results.
I found myself listening to most of my favorite recordings.
I think this is an excellent solution for students,travelers, privacy seekers and headphone fans.
While i highly recommend the use of an outboard dac, you will get good results without one. Especially if you need Bluetooth.
It is versatile device. I intend to take advantage of the free trial. Of 360 degree sound.
Black Friday should have some deals. Get yours today.
That is a problem. I do not have access to the three. I can say the three was only marginally better than the two. I find the four is dramatically better than the two. If I get a chance to compare them directly I will let you know.Now whats the difference between the 3 and the 4 as I believe you are comparing to the 2 correct
