I think they survived, they did loose some money thoughWhat happened to the first 4
And only used on Sundays by a 80 year old man !You are starting to sound like a used car salesman Francisco![]()
Yep Dave, I'd be slapping Peter on the back had he reported in exactly verbatim wording, as a result of a pricey pwr cord to his tt motor. Yes, absolutely.
Hi Francisco,
It's not about cheap power cords, o'rings or toe out. Not zen, the occult nor any other abstraction, getting rid of what hurts you is common sense and in this case the entity is a system. Get rid of what changes the nature of your components with addition, subtraction or distortion and because it's such a simple concept it has elegant simple solutions too but getting it right is fundamental to real advancement. Conversely "Natural" is a simple word and "natural sound" a simple concept, the beauty of all this is its all around simplicity. To me it looks like the objection here and over in other threads seems to be accepting simplicity, and nothing else really. Looking for expansion and verbiage when it's not needed complexity and difficulty when it's not wanted. You don't need a "guru" with "a book" and "the path" just fix what's right in front of you.
david
Edit- The conversation would be very different if Peter had made the same moves but spent a ton of money. $10k power cords instead of inexpensive Ching Chengs, $20k rack instead of his own simple one, $30k for measurements and additional unnecessary treatment instead of simply rearranging the room to manage the sound!
But the band playing sounds better from his deck chair Marc !Peter, you've replace a Vibraplane with steel plate, and one named power cord with another. Swapping deck chairs on the Titanic means you're still on the Titanic.
That's not quite right David. The conversation would be very different and the cult thing would not have thought of if Peter had not mentioned the name ddk.Hi
That's not quite right David. The conversation would be very different and the cult thing would not have thought of if Peter had not mentioned the name ddk.![]()
No dear Tang, everything started long ago with the Boston Tea Party ...![]()
David,
Fortunately your words are clear and exact - as you know I do not object to your methodologies and aims, I understand and appreciate them. However it is not what is being told in this thread and several others. People just replace tweaks by other tweaks, keeping their favorite ones, and consider that they get natural sound, using as main criteria their own reference sounds. They enjoy what they are doing but are far from being simple most of the time.
As I said my interest is not on the equipment, just on the explanations of how it is working and the why's. For example I consider that all power cords are colored, from Nordost Odin to Ching Cheng.
BTW, as far as I remember you never talked about "energy management", the concept that is being discussed.
IMHO the interesting followup is asking what are these comnents worth for consumers and interested audiophiles if they feel that we can get exactly the same effect removing tweaks, adding some toe-out, a few cheap power cables or some O-rings?
Marc buys without much testing, because of the story associated with the car
I've touched on this before. Certainly setup makes a difference but gear probably makes a bigger difference - imo. Granted, even the best gear can sound mediocre if it is not in an optimal set up. But one can spend countless hours on setup, even achieving good results, and still not attain what better or different components can yield. Yes, it's a subjective experience hobby, but imo some gear is better than others.
I agree that gear is important, and as you say, you cannot get beyond a certain level without better components. However, it does not make a bigger difference than setup. The latter is at least as important.
In fact, I would say the better the gear, the more important is optimal setup to get the most out of it. You can put a boombox anywhere in a room and it will make music, and chasing better "set-up" will hardly make it sound better or worse. But the better the gear, the more a less optimal setup will reveal deficiencies in the sound -- or to put it positively, the more a better setup will show what it really is capable of -- precisely because the gear is so revealing.
(my emphasis)IMHO the interesting followup is asking what are these comnents worth for consumers and interested audiophiles if they feel that we can get exactly the same effect removing tweaks, adding some toe-out, a few cheap power cables or some O-rings?
I'm very happy that you approve of my post!
Replacing tweaks with other tweaks isn't what happened it's a claim made by others, the opposition.
In the past I only touched on some aspects of the listening space but never talked about energy management because it's not something that normally comes up. Usually I'm in the room and I deal with the issues, not something I need to explain normally. In Peter's case we discussed things remotely and there was a need to explain and define what he was looking to do, which is energy management vs energy absorption or other strategies.
david
