Yes. Click on the word "Registered" on the bottom right of the Euphony web UI, and it pulls up a little network monitor (essentially "ifstat" in Linux):
Is there a way to get Roon to download an entire album of tracks or is it only possible for just one track at a time? Unless the tracks are long like in some classical multiple part tracks, I wouldn't want to be connecting and re- connecting the network every 5 minutes or so.
I'd be inclined to state there's no such thing as network isolation but that would be controversial so let's call that hypothetical. Going from that as an hypothesis your networking setup is just another means of voicing or shaping sound, like changing interconnects or footers. Something interesting to try is pulling the network cable while playing music, while using different switches and/or network setups and gauge the SQ delta between having the cable connected and disconnected. Someone just using a simple Netgear GS108 will likely find the difference to be pretty minor. The best way to go would be for all Extreme users to use the same switch, we can then configure the Extreme's network ports to interact optimally with that switch, leading to better, or at least more consistent performance across various systems. Having come to that realisation we are now designing a switch ourselves. We are not interested in competing in the switch market, but we are interested in getting similar performance for all Extreme owners, so this switch will only be available to our customers. If it weren't for Corona it would have been available already, I estimate it's about 4 months away now.
I did not realize this, so I just did a quick test, and you are right. However, the behavior varies, so let's tease it apart. First, let's clarify we're talking about the case of a standalone Core directly attached to a DAC — i.e. there is no intervening RAAT communication to an endpoint.
Hi, hopefully TAS is also available to the SGM EVO units .. thanksEmile, Ed...will Extreme Mini also run TAS alongside Roon?
Listening with network connected and unconnected, I'm not hearing any difference -- nothing obvious anyway. I'll wait for the TAS implementation!I did not realize this, so I just did a quick test, and you are right. However, the behavior varies, so let's tease it apart. First, let's clarify we're talking about the case of a standalone Core directly attached to a DAC — i.e. there is no intervening RAAT communication to an endpoint.
So Roon build 571's network behavior is different based on source:
In contrast, let's look at Euphony/Stylus.
- When does preload start: when you hit play
- Qobuz/streaming sources:
- download current track at network speed
- appears to preload enough of next track to maintain gapless, but full track download appears to only happen when the track becomes current. This is different from Stylus (below).
- Local network files from a NAS or SMB share:
- no preload!!
- Appears to be doing normal file reads, which results in some read-ahead, but not a full download.
- Local files on SSD
- did not test, but not relevant to network traffic.
As one of the instigators that drove Željko to deliver this feature, sorry to hear that! For me, the effect of RAM caching the entire queue has always been dramatic. However, the behavior here is also different based on source:
- Either when you hit play, OR
- Click on "Buffer Queue to RAM." This allows you to wait for network activity to quiesce before you hit play.
- Tracks from Qobuz/streaming sources:
- download current and next track at network speed
- when next track becomes current, download the following track at network speed, and so on
- In other words, at most 2 tracks (current and next) are buffered
- download all tracks at network speed, up to limit of RAM buffer (tunable option).
Same here with my meager server and streamer. Happily the Extreme should be here in a couple of weeks or so.Listening with network connected and unconnected, I'm not hearing any difference -- nothing obvious anyway. I'll wait for the TAS implementation!
Indeed WBF member and maintainer @astrostar59 aka "Julian the Fixer" did a great job designing our new website: https://taikoaudio.com/
Will the Taiko switch work in harmony with existing audiophile switches such as M12 Gold/Melco S-100 or as a replacement? Multi units in stack and fitted with fiber as an option?
Fantastic idea, Emile -- taking as much of the local network as possible out of the equation and optimizing what's left (switch to Extreme) for best sonic performance.
Of course, depending on how the switch you offer is configured, there are still going to be differences in ethernet cables, SFPs and possibly even power supplies. But I'd imagine those would fall into the realm of "seasoning to taste" rather than resulting in major differences in sound quality.
Steve Z
I did not know that!
And how about Roon? What were you monitoring there?
Sorry — this is OT for Extreme. Let's follow up in the Euphony thread on AS.
- no preload!!
@heebrog , think it was around 20 once upon a time.
This is what Roon says about their "Maximum Buffer Size" selection.
