I’ve had the beta version for about a week. The sound quality is superb using both players but TBH my ears hear no sonic difference between the two players Only difference is the shorter gap between files.can any of our advance scouting team (aka beta testers) give feedback on the sound quality of extremeDirect vs. gapless playback,
both for streaming media and onboard/local media?
So I think I understand what you have done with the Extreme... A workstation-class ASUS motherboard, datacenter-class dual multi-core Xeons (i9's??), stripped down Windows 10 and enough threads for all remaining running tasks (hence the dual Xeons) so as to minimize any wait times, interrupts and kernel modes, plus custom USB, the Optane boot C: drive, an ASUS Hypercard M.2 for the storage drives, custom memory of some sort, plus all the silent cooling and well thought out power supply, and finally the careful shielding. Then remote-desktop for setup (firewall issues???). I am sure there is more. Impressive. Let me know what I missed.Yes, it’s not very practical btw, as if you want to avoid having to switch your DAC between single and dual AES to play low and respectively high sampling rates you’d have to upsample everything to the highest rate your DAC supports.
What will be the best known in audioYou're very welcomed.
It shouldn't be impossible, though we might have to ask @ray-dude to talk to Dan about the ASIO driver for his SRC•DX
https://audiowise-canada.myshopify....f/products/src-dx-usb-to-dual-spdif-interface
I extracted this driver linked below
https://cdn.shopify.com/s/files/1/1552/8145/files/SRC-DX_ASIO_WHQL_20200106.exe?270
ctaud.infUSB\VID_2FC6 meant that's coming from ComTrue Inc.Code:%CTUAC2.DeviceDesc%=CTUAC2,USB\VID_0EA0&PID_6002&MI_00 %CTUAC2.DeviceDesc%=CTUAC2,USB\VID_2FC6&PID_6013&MI_00 %CTUAC2.DeviceDesc%=CTUAC2,USB\VID_2FC6&PID_f018&MI_00
http://www.comtrue-inc.com/index.php/contact
CT7601 Audio USB Bridge
http://www.comtrue-inc.com/index.php/downloads2/category/4-ct7601
https://www.head-fi.org/threads/rev...phile-vortex-box.787020/page-79#post-14119139
And then there's also this alternative from China (approximately €76 plus shipping)
https://item.taobao.com/item.htm?id=611313177207
An affordable USB DDC that could handle 16fs when both coax ports are connected, some owners of Chord DAVE would be excited to replace the clock inside SRC•DX with an OCXO etc.
IIRC there's at least a handful of Extreme owners with Chord DAVE, most likely it's worth the effort to develop another ASIO driver for CT7601 IMHO.
Hi Edward,Beta rollout road bumps
We expected there to be some road bumps in the Beta install process, so we decided to just start with a handful
sure enough there were some parts that need fixing, so we are taking it slowly until we have got the install package fully sorted
The Good news is that the SQ is there
Hi, I can't wait to get added to the beta but I have a question. I see a lot of discussion centered around the SQ with the USB DRIVERS. I do not use USB but I use a ethernet "Sablon" cable via the M12 Switch Gold. Can I expect similar improvements as those using thr USB cables with the new TAS? ThanksBeta rollout road bumps
We are still sorting out the appointment booking calendarsHi Edward,
Is that the reason why there was no email with appointment schedule and manual that you talked about in a previous post ?
Which DAC are you using ?Hi, I can't wait to get added to the beta but I have a question. I see a lot of discussion centered around the SQ with the USB DRIVERS. I do not use USB but I use a ethernet "Sablon" cable via the M12 Switch Gold. Can I expect similar improvements as those using thr USB cables with the new TAS? Thanks
I'm using the MSB Reference DACWhich DAC are you using ?
According to our data points, we are confident you will getnoticeably better SQ having one of the USB interface options installed in the Reference DACI'm using the MSB Reference DAC
I'm using the MSB Reference DAC witWhich DAC are you using ?
Thanks for the info. I currently just have the The MSB Network Renderer V2 but I will see if I can try out the MSB USB Inputs or the PROISL. Maybe pickup a USB from Mark while I'm at it or go Fiber... Thanks again.According to our data points, we are confident you will getnoticeably better SQ having one of the USB interface options installed in the Reference DAC
But isn’t coaxial is limited to 24 bit compared to USB 32bit?I was thinking same. Once Emile and team finish finalizing USB details with the new Taiko USB card, I'd be quite keen to explore a USB to dual SPDIF converter. The USB chipset on DAVE is definitely one of the weakest points in the system
Chord's tendency to cheap out on critical things like power supply and USB chipset in a $10k+ flagship DAC is very disappointing. We can fix the power issue, but fixing USB is much harder. I'm keen to take a crack at it though
Does your Extreme Player or Gapless Player require your USB driver? Can one use driver come from Chord with DAVE?The Chord Dave uses a proprietary Amanero based USB interface we cannot do much with (we did try). It simply performs best when being fed a 32 bit data stream. Which is why, afaik, all of our customers use it with HQPlayer and upsample to 32/768. When using TAS you would therefor select the HQPlayer output which bypasses all our bit-perfect player optimizations but the files do still go through our noise mitigation process.
Extreme Serial and Batch will pass data to all ASIO compliant USB driversDoes your Extreme Player or Gapless Player require your USB driver? Can one use driver come from Chord with DAVE?
