can any of our advance scouting team (aka beta testers) give feedback on the sound quality of extremeDirect vs. gapless playback,
both for streaming media and onboard/local media?
There should be no difference.
EdExtreme Serial and Batch will pass data to all ASIO compliant USB drivers
I was thinking same. Once Emile and team finish finalizing USB details with the new Taiko USB card, I'd be quite keen to explore a USB to dual SPDIF converter. The USB chipset on DAVE is definitely one of the weakest points in the system
Chord's tendency to cheap out on critical things like power supply and USB chipset in a $10k+ flagship DAC is very disappointing. We can fix the power issue, but fixing USB is much harder. I'm keen to take a crack at it though
Does your Extreme Player or Gapless Player require your USB driver? Can one use driver come from Chord with DAVE?
Ed
what is the buffer capacity of the serial and batch players
I know you said 20 files for the batch. I’m getting that as well on the serial player
I'm signed up for the Beta and I'm currently running a pair of Dutch & Dutch 8C active speakers so the DAC is in the speaker. The speakers are connected together with AES and one is connected to a Lumin U1 Mini by AES. The Extreme is connected via ethernet to an ER which feeds the Lumin and the speakers so there is no direct USB or AES connection to the Extreme. Will I be able to get the TAS player?
Thanks for the info. I currently just have the The MSB Network Renderer V2 but I will see if I can try out the MSB USB Inputs or the PROISL. Maybe pickup a USB from Mark while I'm at it or go Fiber... Thanks again.
Right, I figured that out. So to get the TAS driver involved I may have to remove the lumin and go fiber>Extreme>USB>Berkeley Alpha USB>AES D&D 8C. Does that work?Both the Lumin U1 and the MSB Renderer V2 are Roon endpoints. You can only drive them using a Roon core.
The network endpoints you can use with TAS are Ravenna (Merging DACs) and HQPlayer NAA.
Or fiber>ER>ethernet>Extreme>USB>Berkeley Alpha USB>AES>D&D. I could then run ethernet from the ER to each D&D which is useful for tuning. Seem OK?
Then that's what I'll do.Yes, looks ok.
Thanks I appreciate the response. All things consider would I be better served with the PROISL module or the USB module from MSB? Thanks againBoth the Lumin U1 and the MSB Renderer V2 are Roon endpoints. You can only drive them using a Roon core.
But isn’t coaxial is limited to 24 bit compared to USB 32bit?
Thanks, appreciate it!If you want the ultimate interface, go with the MSB Pro USB to ISL.
The output impedance from the unbalanced and headphone jacks was extraordinarily low, at <0.5 ohm. The balanced output impedance was a still-low 66 ohms at all audio frequencies.
https://www.audioexotics.com/wp-con...adax-Atlantis-Reference-Dac-Review.pdf#page=9Outputs: Balanced on XLR jacks
Output impedance: 0.15 ohms, 10 ohms, 50 ohms, 75 ohms, 600 ohms, user selectable
A forthcoming software update will provide 16 levels of output impedance rather than the five levels in the review sample’s software.
1% THD 6.8v RMS with 33? (1.4w)
https://www.audioexotics.com/wp-con...adax-Atlantis-Reference-Dac-Review.pdf#page=9variable output impedance, variable output voltage (1V, 2V, 4V)
The analog output stage reportedly plays a large role in the Reference DAC’s sound. It is a three-stage discrete differential circuit that can deliver a robust 1W of output power—a level far higher than that needed to drive a preamplifier’s input.
Hi, I have a clarification question, if I could. I went back and read the post in the MSB owns section of WBF and I get this part just fine.If you want the ultimate interface, go with the MSB Pro USB to ISL.
