Selecting DSD512 would be best.
Thank you, Christiaan.
This is specified in the "Taiko Audio Extreme Roon Settings" doc on the Taiko Extreme page (scroll to the bottom of the page): https://taikoaudio.com/taiko-2020/extreme-music-server/
Hi Christian. I have been checking my "Device Setup" in Roon and it is as I accompany in the screenshot. However, in the manual I cannot find information on how to configure the following two inputs: Use power-off-2 Buffer sizes and Multichannel mixingThis is specified in the "Taiko Audio Extreme Roon Settings" doc on the Taiko Extreme page (scroll to the bottom of the page): https://taikoaudio.com/taiko-2020/extreme-music-server/
Hi Francisco,Hi Christian. I have been checking my "Device Setup" in Roon and it is as I accompany in the screenshot. However, in the manual I cannot find information on how to configure the following two inputs: Use power-off-2 Buffer sizes and Multichannel mixing
While searching for more information on Roon Settings I came by this unofficial User Guide that was created from the Roon knowledge base content by Michael Whitehead.
Not sure if it has been posted previously nor how up to date it is. Might be helpful if you are not aware of it.
Roon User Guide by Michael Whitehead
I was listening to the BBC broadcast last week of Fairport at the Cropredy Festival (the first one 3 years!) and experienced a problem with TAS that I don't understand.
The concert was parsed into separate cuts spread over 3 discs, all in the same directory.
When I loaded the directory into TAS, the queue showed tracks out of order as follows:
T1
T10
T11
T12
T13-T19
T2
T20
T21-T26
T3
T4
Any idea what is going on with the queue ordering? I'd love to understand this.
I'm sure XDMS will not have this problem.
TAS is ordering the tracks in ascending numerical order, looking at the leading digit first. As @dminches says, appending a zero to the start of each number will re-order the sequence correctly. I haven't found a setting in LMS' server, player or settings that would do so automagically, or would correctly order the tracks.I was listening to the BBC broadcast last week of Fairport at the Cropredy Festival (the first one 3 years!) and experienced a problem with TAS that I don't understand.
Metadata looks fine in Tagscan.
T1
T10
T11
T12
T13-T19
T2
T20
T21-T26
T3
T4
2 comments:
1 - The track numbers should all have 2 digits. 01, 02, etc
2 - if you look at the metadata of the track number is it populated?
There is nothing I have yet to experience with Wilson where he says it can not be done. He always finds a wayThat's it then, no leading zero.
Now, that is true of much of my music and would be a PIA to deal with.
@Ed
XMDS will be smart enough to deal with and without leading zeros, right?
Alas, for TAS, this should be fixed in the tracks' metadata.TAS is ordering the tracks in ascending numerical order, looking at the leading digit first. As @dminches says, appending a zero to the start of each number will re-order the sequence correctly. I haven't found a setting in LMS' server, player or settings that would do so automagically, or would correctly order the tracks.
Steve Z
@Ed
Is that viable for 90k tracks?I would fix the metadata instead of relying on the software to try to figure it out. It shouldn't take too much time to do this in a good tag program, like Tag&Rename.
Fyi, I use Tagscan but would happily purchase a program that could batch process all my music
Cool. Can you point me to a guide or example of how to batch implement this?Absolutely. I have spent 2 years constantly working on metadata. Plus, my guess is that less than 20% have issues.
First, let me thank folks for their comments and suggestions.As someone who's obsessively "groomed" the metadata of their digital music files ever since I first ripped my CDs back in early 2000s, I sometimes forget that not everyone does that. And if you don't, then you are always going to have problems with any music software (like LMS) that relies solely on tags. That's because a subset of digital music — @dminches 's guess of 20% seems about right — is atrociously tagged by the labels.
This was one of the huge positives of Roon, because it broke the reliance on file tags for music organization. Roon uses a 3rd party music database vendor (still Rovi?) for the actual information about albums, and only used the file tags as a means to identify an album in their internal database. Even this isn't perfect, but it's much easier for the perfectionist "groomers" like me to plug the remaining gaps.
I seem to recall @Taiko Audio and @EuroDriver mentioning that XDMS would use a similar service to identify albums, rather than relying on file tags exclusively. Perhaps Ed can clarify that this is still the design point.
If so, then these issues with poorly-tagged files should be easily surmountable. If not, it may be time to don your boots and start grooming! I personally use and like MP3tag on WIndows.
I actually do obsessively groom my tracks, I just seem to have missed the leading zero issue.
Every album has been through Tagscan, and I ensure the disc and track numbers are correct, then rename each file as:
"d-t track" where
D is disc number
T is track number
Track is tagged name of track
All the disc and track numbers were carefull checked. In what bizarre computer coding universe is 10 less than 2? Some dumb integer sort to save comparisons??
a legacy of a time when coders optimized for simplicity?
Why?????
Roon is a no go here, even if it sounded good as I detest the interface and keep my music in a logical folder structure that works beautifully for me and has been groomed and adjusted in the decades since I first ripped all my CD.
Also, much of my music cannot be tagged by any external service as it will not be found. For example, I have a lovely recording of Fairport Convention playing live at Cropredy from a week ago, as broadcast by the BBC. I carefully checked all the titles, disc numbers and track numbers. It just doesn't work correctly because some stupid software (lms' fault, not TAS) can't recognize that 2 < 10.
I need to check how some mobile apps treat this issue before I decide how much effort to put into adding leading zeros. Pray for me.
