DOP fix will be in the backend updateHas anyone been able to get XDMS to play DSD on a non-DSD-native DAC like the Chord DAVE? It seems that the option to choose DSD over DoP is not available in the XDMS interface yet.
On iOS, TestFlight can indeed update automatically when a new version is pushed (when the app's toggle switch is set to Automatic Updates).No problems here w the Build 31 push. Just showed up a bit ago that the software had been updated. Just had to reconnect manually to the Extreme through XDMS (settings icon then ‘connect to Extreme’) and enter the IP address (same one seen on VNC viewer). Excellent. Excited about any incremental improvements.
Please note that folder import is not yet operational. You can add music by re-scanning the music folder using Library Scan --> Clear XDMS DB and Scan.Is the “import new items from the import folder” functionality working? Just wondering how I add new music.
Please note that Import Roon Playlist is currently not yet operational.Brilliant!
Thanks!
No I don't have XDMS installed. But I'm looking forward to it.
In fact, I haven't even activated my Extreme yet.
It's been sitting in my office with the rest of my HiFi for a few weeks, waiting for my listening room to be finished.
On iOS, TestFlight can update automatically when a new version is pushed (when the app's toggle switch is set to Automatic Updates) so no user intervention is needed at all.Hi Ed. I would like to know your answer to this question: once the alpha version of XDMS is installed, the successive updates, be they alpha, beta or definitive, no longer require Ed to connect, but only press the "update" button?
Same here, that fixed it for me as well.FWIW, when I upgraded to build 31, XDMS stopped working. Something must have happened to the player.conf file. I overwrote the current version of the file with the backup copy and XDMS started working again. Thanks @nenon .
Thank you for the clarification Ed!To all eager XDMS Alpha testers, the two step process to get the iPad app is proving to be torturous
we are therefore transferring the next App version 32 to a new Taiko Audio Developer account with Apple but it takes a couple of days
Appreciate your patience
Thanks once more for the reply, and yes that's exactly why I want to try removing the OPTO.DXThe OPTO.DX is a premium product, but not necessarily the best for your application.
The Taiko Extreme changes some of the rules. Generally speaking, the less components you have between the Extreme's USB output and your DAC, the better.
While the OPTO.DX may do a good job "decrapifying" the crappy USB signal of noisy computers, it kind of gets on the way when used with the Extreme. Even the SRC.DX does, but bypassing the Amanero on the DAVE DAC does more good than the damage of adding another component in the digital output path. And you are up for a positive net (SQ) result, which is all that matters in the end.
I will just remove the OPTO.DX here. Haven't tried the DC.BLOCK myself but I've heard from other people with Extreme -> SRC.DX -> Chord DAVE that they like it, so something for you to try and decide.
With XDMS I have no desire to go back to HQPlayer on the Extreme. Even TAS changed that for me.
@DW101 - shoot me a DM or an email if you have any questions, so we don't get into a Chord DAVE specific discussion here.
Yes, although you can also just use firebase…Is there an equivalent for Android, like Google play console?
Dear Edward,To all eager XDMS Alpha testers, the two step process to get the iPad app is proving to be torturous
Thank You for sharing! Do you control the Nvidia shield pro with some factory IR remote? If yes, I can turn off the wifi we use for our Ipads!A quick adder. I am also running the apk alpha on an Nvidia shield pro (android 11) which is my video streamer in the home theater.
Here's the xdms app running on the shield pro, upscaled to a 65" 4k television.
It's not how I do things here but this would be useful to those who integrated their audio and video systems.
I am not able to play DSD because my DAC uses DoP. CheersJust inquiring if everyone using XDMS is able to play all musical formats. I have been able to play all of my 352.8 DXD files as well as all my DSD256 and DSD512 files. The load time of each film e was silly long in some cases. I was about to give up when the files started to play. So I am able to play all of my files
Less than 5 percent are AndroidChristian
Can you tell us what you see for the relative percentage of ios vs. android users?
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
