The American Sound Turntable- Beyond's Minimalist!
And that approach is… ? What can you tell us?
(Is there someplace this is all detailed?)
i’m not at liberty to discuss it Bob. it’s probably best to move the conversation along to a different topic. This thread is not really the place to discuss the new turntable. This thread is about the original American Sound turntable.
David Karmeli is no longer here and Bonzo started the discussion by sharing a private video. So I started the new thread on the subject of the new turntable.
Reactions: Argonaut and Bobvin
hi Peter, that’s not a private video. It is on Facebook and David’s YT
Reactions: sujay
Not on David’s YT when you posted it.
the link I have posted is to David’s YT. That’s where the readers of my link heard it
it's not listed on that YT page, but the link takes you there. so it's 'hidden' and 'private' and not on the open page. not findable by search or accessing the page, you need the link.
Reactions: PeterA
ah ok. I copied the link from FB
Exactly right Mike. I can’t find it either on his YT channel. They are private at this point. The videos I posted were sent to me by David and he told me I could post them on the new thread.
The air gap between the two sliding surfaces is only a few micrometers. If these are damaged by a drop in air pressure or leakage, the bearing is scrap. There must be a safety feature for emergency operation. Today there are other good materials that no longer require lubrication, e.g. S-green(c) plastic.
Well you could but you gotta keep the temp constant .
For example teflon bushings expand a lot
We have mixers running at 200 ° C .
And we had major problems to find the right material for the bottom bearing application
We give a 60 mm teflon/ glass bushing a 2 mm manufacturing clearance with a stellite shaft sleeve .
Expansion is about 1.5 mm iow clearance is only O,5 mm at working temp
Room temp is different off course but with those tight airbearing tolerances it could be an issue .
If for example the workshop temp is 15 °C and the living room temp is ranging from 18 - 24 °C
it was posted by Andrew Tan on FB
For example teflon bushings expand .
Depends a lot on material expansion coefficients how tight the tolerances end up.
Tw-acustic uses for bottom bearing S-grün with steelball
exactly. ask people who have an old Apolyt the airbearing cannot rotate below 18 degrees room temperature.
P.S
If you want to buy an air bearing then buy from Aerolas, they are the market leader for this kind of thing. The quality is far better than anything else.
What help were you ?
So, IF you don’t mind my asking, who are you to ask such a question? ( How many American Sound turntables have You set up? Have you ever heard one? )
Simply asking to inquire about your challenge to PeterA, who is something of an American Sound TT expert, though he would never be the one to say so.
As stated, with any respect that might be due, what is Your experience with American Sound turntables? What do you know of their design principles, construction, function or performance?
I’m most keen to learn.
Reactions: trekpilot and tima
As a member of this forum I can ask whatever question I like within the confines of the forum rules , thats who I am .
My experience extends as far as a good 99% of other forum members who are relying upon a couple of interviews conveying little real detailed technical information regarding these turntables other that a handful of sound bites emanating out of Utah via Boston , together with the endless promotion of these turntables, and the maker, on the forum by a handful of the manufacturers acolytes of which you are one of them .
I see that you have had your string pulled .
Thanks
https://www.newwayairbearings.com/catalog/air-bushings/
Have a look at this site for an example of an air bushing. The manufacturer of the bushing would specify the needed "clearance" between spindle and bushing along with a recommended air pressure.
Scott
Below sentence from the link you shared drew my attention and offers a solution to the biggest problem cause IMO the real concern on an air bearing platter is thrust.
If your usage case requires one end to be constrained axially, we also offer thrust bushings as an extension of air bushing technology.
Thanks for sharing.
What happens if the electricity goes off?
ddk designed his tables to be driven by Purepower, or some such power thingy
Reactions: sujay and Lagonda
Audio is a combination of science and witchcraft , easy to see the warlocks from the wizards ..!
