Tricky to satirise some of our top leaders and ex-leaders when their very essence is pure satire already.
Where you sitting near field before Marc ? What are the dimensions of the triangle now ?Had a welcome visit from Barry/Blue58 today. I know it's a chore for him to listen to my Zu-based system since he's immersed in horns for a decade now, but his frank opinions and practical suggestions always welcome. I'm as sensitive as the next audiophile to criticism but as long as those comments are heartfelt and predicated on logical arguments, they invariably should help.
Barry is coming from a situation where he has fine tuned a feisty Extreme install, and we've both heard Audiophile Bill's superlative horns/Mayers tubes setup, so opinions now are based on fantastic data points.
My setup is still not massively to Barry's bias...how could it be since horns will always have the advantage of dynamics, liveliness and immediacy. He's in two minds about my PETs acoustics fit-out, but I held my ground and disputed his take my room may be over damped. On multiple occasions I compared my room minus all treatments, then w GIKs, then PETs, then out again...wash/rinse/repeat, for several cycles...and strongly concluded my sound was overly damped w the GIKs and a tad too harsh w no treatments.
Where we also initially disagreed but I then came around to his way of thinking was on moving my listening chair back significantly. He felt my sound at listening distance of 11-12' was a little phasey, sound locked to spkrs and centre image a little hazy. Upon moving the seat back another 6' he felt the stereo image shored up, effectively a more hefty homogenous soundstage less prone to locating to either/both spkrs.
I initially didn't take to this, but one track nailed it better at the greater distance, and from then on, every subsequent song sounded better.
This then struck me as one of the things I noted strongly at Bill's horns demo, and what I've heard recently at classical concerts we've attended. That facet of a slightly mid-hall like perspective, music drawing you in, a much smoother curved wavefront of music presentation, less "panning" to R or L...and then within that greater space for music to breathe and present depth cues.
It's a little bit of an un-learning experience, and only possible in my extra deep audio space, but Zus 8' from front wall, my seat now 17-18' from the Zus, another 15' to rear wall, is making for a new, more holistic listening experience.
Whatever sounds best is the way to go Marc, find the place where the frequency's come best together. You might have to revisit your sub crossover settings too !Well, I was closer to 11-12' from my Zus 8' apart. Now up at 17-18'. I know the trend is to be closer to even v tall tower multi driver spkrs, a la Mike Lavigne 9' from his 7' high 4-pc MM7s. I guess I'm stretching the envelope Lol.
Don’t get him started on sub settings again, please!Whatever sounds best is the way to go Marc, find the place where the frequency's come best together. You might have to revisit your sub crossover settings too !![]()
Barry, I value your opinions as ever. Who else could get me to consider moving my seat each time you visit, and at first grudgingly accept you had a point, and then see the light on change. I also agree on BPT, I'm getting an electrician to help me move it outside the room.Always good to catch up with Marc and Ra and enjoy a lovely meal and a beer, thank you Marc.
His sound imo has taken a step back. I said the room was LESS damped than before and I believe the change to PET absorber/diffuser is a step in the wrong direction. I proposed a combination of GIK absorbers and PET absorber/diffuser to trial next.
As for the listening position. At greater distance the Zu cross over in front of the listener, the recommended Zu placement. At close distance the Zu cross over behind the listener with the tweeter almost firing into your ears. The distant listening position brings the 3 images L/R/C away from the speakers and connects them together allowing a larger image and more focus musically. The Zu also appear to be further apart than 8feet perhaps 9feet and may be too much.
Marc, you really need to buy a couple of laser pointers and a laser measure to at least centre your chair and align the speakers symmetrically.
And please get rid of or move that BPT before my next visit.
Cheers
Blue58
Addendum. I added two extra GIK panels in my room and for three days thought the sound over-damped but with added clarity and larger soundstage. On the fourth day I didn’t notice the over-damping which tells me that you can’t just swap in acoustic treatments for a quick comparison but have to listen for a few days before making any judgements. I’m also learning REW software which is another rabbit hole of madness.
Barry - you clearly need to visit Marc for 4 days next timeI added two extra GIK panels in my room and for three days thought the sound over-damped but with added clarity and larger soundstage. On the fourth day I didn’t notice the over-damping
Hi Phil,Barry - you clearly need to visit Marc for 4 days next time
Seriously though what did you think changed about the presentation that made the room seem underdamped - were the high frequencies too smeared - the PET panels only have a nominal absorption and their role is really only redirection the first reflection away from the listener and theoretically improving clarity, imaging etc. - its the location and angle that's important and the material could be anything - PET is easy to use and has the advantage of calming down the reflections a bit
The theory is if the room seems too lively you can add broadband absorbers out of the first reflection areas
Not sure of the type of GIK type panel used but if it is a broadband absorber they would typically start to work from 200Hz or so upwards and should not have an impact on reverb time
On listening position, further back you go the more of the room you hear and I would expect it would suit some music ( orchestral ?) more then others such as closely miked jazz, chamber music etc.
Very interested to hear your thoughts
Phil
