Blunt response!
And your’s Nonesup?!? I gave an answer to the question - geographic distance is not a barrier.
Blunt response!
I guess Google translate did an incorrect translation for me. The phrase in Spanish was: "Respuesta contundente".
I do not know what translation will have been done but what he intended was to say that his answer was conclusive and therefore was not a criticism, but quite the opposite.
regards
That's why many of up are visiting and learning from forums.
There are many kind and genuine formers, but also some who maybe shills and say fantastic things about a product but refuse to share further when asked.
I was lucky to try the Vetere and was sold, there are many forums in the Hong Kong where CAS is very big and there is a wealth of knowledge base especially on this very topic.
I had also the opportunity to try the Goebel, a very good cable, sonically top notch too but as much as I liked it, was not sold.
CK who contributes heaps to forums and I thank him with is every reading willingness to share what he has heard or use.
Some comments mirrored my own views after trying and owning some of the cables.
The Vetere is most musically balanced and a steal for its price. Next is the Goebel which has its signature sound which some will like and some won't.
Then came the Dalby Meda, which fits perfectly in between and sound neutral, yet musical while harmonically solid.
By the way, bit is the entry level cable offered by Dalby.
Many other cables may have sounds that just sound 'broken' and the notes just don't seem as complete after comparisons.
But again, that is when you have optimised your networking infrastructure, I strongly believe the Vertere will shine at the earlier stage of starting to refine the networking environment or should I say networking system.
do you Have the new Merging Nadac Player??, are you driving amps directly??Started with STP...now using UTP as per Merging.
Email me and I will send you a demo cable tomorrow!
I now have about 200 hours on the Sablon Audio Ethernet cable. I replaced the .5m of wireworld between foil filter and dac with the Sablon and the difference was astonishing. The Sablon just draws you into the music, just like an analog record. The wireworld is way more mechanical sounding in nature. The Sablon's tonality on instruments is spot on. Am I impressed, you bet.
Hi, Ventor,do you Have the new Merging Nadac Player??, are you driving amps directly??
sweet Goebel cableAt least one WBF member (other than mine) who has this cable.
http://www.transparentcable.com/products/show_product.php?recID=100&catID=3&perfID=1&modCAT=1
Dark sound without resolution with very poor connectors....
Bruce I am like you in this until I tried the FTA oneJust using what came with the unit (Merging Horus). Tried Audioquest Dragon.... no change..... waste of $$$
