These are the recording professionals statements in the original article in post#1 by Steve that appear to make the case for digital (all things equal) being the closest to the recorded performance.
"Of vinyl's inherent deficiencies, reproducing bass is one of its most glaring."
"The other is that the last track on each side of a record sounds worse than the first, due to the fact that the player's stylus covers fewer inches of grooves per second as it gets closer to the center."
"In the 1960s and '70s, when artists were recording specifically for vinyl, they recorded and mixed to fit the confines of the medium, he explains. They kept sides below 20 minutes, and put loud songs on the outside tracks and quiet ones toward the center to account for the natural deterioration of sound that occurs when the needle gets closer to the middle of the LP."
"To get an album longer than 40 minutes to fit onto one LP, Lyman says, high frequencies and bass are the first things that go. There's also extra distortion because he has to cut the master lacquer at a lower volume to fit all that extra music onto the LP."
"From a record player, it's impossible to have such a dynamic range," Immink says. "You have to suppress the dynamic range, otherwise the grooves will touch or you [have reduced] playing time."
"Because vinyl's restrictions do not permit the same abuse of audio levels as the CD, Mayo says that listeners might hear a wider dynamic range in an album mixed separately for vinyl over a compact disc version optimized for loudness — even though vinyl, as a format, has a narrower range than CD."
"I think some people interpret the lack of top end [on vinyl] and interpret an analog type of distortion as warmth," says Jim Anderson, a Grammy-winning recording engineer and professor at New York University's Clive Davis Institute of Recorded Music. "It's a misinterpretation of it. But if they like it, they like it. That's fine."
"Most notable among these is "audiophile-quality 180-gram vinyl," which consumers assume is superior because it is heavier. Lyman, however, says the added weight offers no musical benefit at all."
"Scott Metcalfe, for example, says that recording to analog tape isn't any purer than recording music digitally. But the distortion and pitch variation that analog tape adds to the recording are preferred by some artists and audiences."
