Ideal Network for Audio?
Germanboxers
96
168
265
I could really use some help from you network and network audio experts. I will be replacing my lampizator Golden Gate Dac fed via USB from a capsv3 computer (linear power supply fed) as an NAA (roon + HQPlayer in office does the heavy lifting) in the music room to an MSB Reference DAC with renderer V2. My intent was to move the capsv3 computer near the switch in the basement and just plug in an ethernet cable into the MSB renderer.
Attached image shows how the network is arrange. What is the ideal network arrangement for Audio? Any other thoughts?
Reactions: jaynyc
CKKeung
3,063
3,201
1,410
Hong Kong
Hello Germanboxer,
Possible to replace your Cisco switch in the Basement Utility with a SOtM sNH-10G switch and run an optical fiber to another SOtM switch in your Music/HT Room which then connect your MSB Ref DAC with a good ethernet cable such as Vertere/Dalby Audio Meda?
I guess you will give LPS to all the network components.
jturbo
130
90
133
Lexington, KY
Hello Germanboxer,
Would you still use LPSes on the upstream cisco and sotm switch?
If so, im wondering how the noise is introducing across the fiber between the sotm switches. Or do you think there is another mechanism at work?
CKKeung
3,063
3,201
1,410
Hong Kong
If feasible, please use LPS for the whole CAS/network system.
Friends and I did comparison.
Even one single switching psu in the house will make the sound worse.
IMHO please remove all such switching psu from the wallsockets, even if the electrical appliance supplied by them are not turned on.
You may do such an experiment at home easily.
I am not a tech guy but believe that switching psu will pollute the powerlines of the whole house.
jturbo
130
90
133
Lexington, KY
This is a measurement on ground (safety earth) with a smps plugged into the powergrid. You will measure this everywhere in your home. The scale is in KHz.
I use a torus isolation xformer. Would that filter the rest of the house? If not, our houses are full of dozens of low end power supplies.
I think my spouse would love me putting the entire house on power strips to clean up the audio.
I think the advertisement would be to eliminate phantom power.
Taiko Audio
4,313
13,456
1,925
The Netherlands
taikoaudio.com
Usually the secondary is referenced (connected) to ground (safety earth) so it does not do anything about this unfortunately.
Reactions: CKKeung
4,704
IMHO only if you do not take proper actions to isolate your audio mains from disturbances or your system has abnormal susceptibility to mains or ground noise.
Systems have such variance that IMHO in these aspects we can not expect that what results in our system results in other systems.
