FARAD SUPER3
Farad is a new brand that comes from the Pink Faun stable. We have a first version with a housing that can still change. Technically, however, it will remain the same. That means that we can take this into account in the test.
The Farad has one output with a voltage of 12 volts in this case. You can choose between standard cables or a chic cable with a nice boot and a kind of carbon plug. (additional charge 60 euros).
The design of the Farad is a bit different. This is mainly due to the super caps (hence the name Super3) that Farad uses. That also means that this power supply needs to charge for a while before we can switch it on and start using it. Count on about 30 seconds before energy is transmitted. The same applies the other way around: draining the Farad takes a while ... It really is a kind of super-battery.
MEASUREMENTS
Farad Super3
Voltage loaded: 11.8
Voltage unloaded: 12.14
Noise max: -122 (55 KHz)
Noise min: -145
Sjonge… (WOW!) how good the Farad Super3 measures! There is actually no noise at all. So this is going to be a very boring story. We see nothing at all on the AudioPrecision: a stable noise level of around -140 dBV to around 1 kHz. From 1 kHz we see that it rises slightly towards the 50 kHz. But yes: around -130 to -125 dBV, so what are we talking about?
The square wave also comes through nicely, although it seems to be slightly muted. Perhaps the result of a coil or the supercaps ...
LISTENING
Rest, rest, rest ... The Farad is a special product. It lifts the Mytek one level above that of the Sbooster. We hear more black, more music. Purely because of the silence it can bring. The voice of Beth Gibbons is completely loose (intended positively) and has received a beautiful natural timbre. No hardness. The edges around the high hats are also completely gone. The dac is also no longer close to busier, more complex work. Very special to hear this. If you think it can't be better ... It can be done. Absolutely a top product.
