That's a good one!we are not re-writing Shakespear
I'll definitely use it.
Well, Christian denied the possibility of Christmas coming early, so...Earlier for sure, we are not re-writing Shakespear
That's not what I meant. I responded to Steve Williams' mention of Edwards's earlier prediction that this could be the last TAS round. What I was pointing out is that Emile had supplied a later update after that, which I outlined in the excerpt. As for timing, we just can't make any promises at this stage. Please trust that it is as soon as possible.Well, Christian denied the possibility of Christmas coming early, so...
Japanese, korean and chinese is what I listen a lot to.The interesting thing is that I can see my Japanese titles on TAS but couldn’t in Roon.
Benchmark is currently not on the list of supported DACs. I will check internally if it can be added. FWIW, the list of compatible DACs can be found on the Extreme page on the Taiko site, just look for the document labeled "USB Profile Selection Guide" at the bottom of the page: https://taikoaudio.com/taiko-2020/extreme-music-server/Does anyone know if the taiko usb driver supports the benchmark dacs?
Yes, but I can't say much vs the previous build. To be honest tube rolling in the Horizon probably yields more noticeable differences than Roon rolling at this point. Hopefully, Roon rolling will be nullified by XDMS.I'm afraid to even ask: Has anyone installed Roon Build 1021?
1021 on both iPad and Core@Zeotrope: Which version? Go into Roon settings/About/and it will tell you the version you have installed. Former version 988, now with update 1021...
Hi John = With some trepidation I hit the Roon update to Build 1021. No discernible change for the worse or better, whew!I'm afraid to even ask: Has anyone installed Roon Build 1021?
Christoph started a WBF thread devoted to Roon updates and sound quality:Hi John = With some trepidation I hit the Roon update to Build 1021. No discernible change for the worse or better, whew!
Is there a particular Roon build that people think sounds the best?Christoph started a WBF thread devoted to Roon updates and sound quality:
Sound Quality of new roon versions (builds)
Hi fellow roon users After every new roon build is (rarely) hit and (mostly) miss sound quality wise and roon's own forum is completely agnostic and even hostile when it comes to sound quality o_O, I thought it makes sense to have an according thread here on WBF because WE really care about the...www.whatsbestforum.com
Good place to periodically check (or subscribe) for SQ issues with new Roon builds.
Steve Z
Follow up. Sound is coming from TAS again, but not from the 2 albums I was having the issue with. They were playing on Roon however.... Very strange as both are Qobuz.New TAS issue. I have a good collection of tricks in my tool-bag I use to get TAS back up when it goes out, but none are working for this one.
This time it shows the track playing, but with no sound. In the past this would indicate the DAC needs to restart, or pull usb cable out/in, however that's not working this time.
Roon is working.
Any ideas?
I used every trick in my book -- 5 of them!@wil: I take it you did do a soft restart on the Extreme?
