David…… be careful. set it and forget it until you get a new DAC
I am not looking to change it. I just don’t see it in the config file. Either way, I have the file backup up so there is no danger here.
as long as you are getting great music what does it matter where it isI am not looking to change it. I just don’t see it in the config file. Either way, I have the file backup up so there is no danger here.
It’s dangerous for me. When Ed does stuff with my computer I look in another direction. It’s well above my pay gradeI am curious plus I already had to edit the file after XDMS wouldn’t load following the new version. The new version trashed the config file so it needed to be changed.
You aren’t a programmer so this stuff doesn’t interest you.
"The DAC profile sets the buffer size and once a new profile is loaded (from the Extreme desktop) it stays until someone manually loads a different one". --> CorrectSomeone will correct me no doubt if I've got this wrong, but my understanding now is that the DAC profile sets the buffer size and once a new profile is loaded (from the Extreme desktop) it stays until someone manually loads a different one. Eventually that looks to be configurable in xdms, perhaps, or perhaps auto-loaded based on one's chosen dac--I'm just speculating here, of course.
The config setting discussed was to set the bit size, I believe, and I understand why Taiko would prefer to make such adjustments themselves--I think they're afraid, and I can't disagree, that their support load would go way up (as though it weren't already over the top) if all of us alpha users started 'tinkering' on our own in the backwaters .
Jerry
Nice amps!Too fast, thanks Mr Ed for your support!
To switch to Roon, you need to start the TaikoRoon service in TaskmanagerRight now I have both roon and XDMS apps on my ipad.
Can I simply switch from one app to the other?
Or should I better be happy with what roon now does in my system (not bad!) ?
Not to get into trouble again.
While I do enjoy video calls with Ed I think his time should better be invested to get XDMS running perfectly.
Cheers, Ulrich
Just loaded version 5 and I now have buckets as opposed to a TAS like layout. Is this to be expected?To all XDMS users alpha version 5 was just released though test flight
If you have some familiarity with Windows it is not difficult, otherwise it is better to refrain. You must first Ctr-Alt-Delete the Extreme and access the Task Manager. Choose the Services tab. Find the services (scroll to the end) xdms-player and xdms-server and right-click on them, choose stop. Now find TaikoRoon service and right click Start.Right now I have both roon and XDMS apps on my ipad.
Cheers, Ulrich
Indeed, the buckets (which will be renamed) are for now to stay. We will add Tile views (cover art) shortly.yes. However, the gallery view will return (according to Ed).
I can switch back and forth between XDMS and TAS by tapping the icon on my iPad. I can get Roon by going to TAS control. I'm guessing I have both XDMS and TAS running which isn't good?If you have some familiarity with Windows it is not difficult, otherwise it is better to refrain. You must first Ctr-Alt-Delete the Extreme and access the Task Manager. Choose the Services tab. Find the services (scroll to the end) xdms-player and xdms-server and right-click on them, choose stop. Now find TaikoRoon service and right click Start.
