That does not answer my question
Yes, I know. I am sorry my post was off-topic.
I feel that is the consensus opinion. And to add further clarity, I'd suggest fiber optic as the last step in the network chain to prevent any noise transmission.Is it now generally accepted that it is good to have fiber optic somewhere in the line prior to the streamer to isolate and to scrub noise off the the upstream ethernet cable?
Thank you.I feel that is the consensus opinion. And to add further clarity, I'd suggest fiber optic as the last step in the network chain to prevent any noise transmission.
i suppose you mean two S100 and not Melcos ADOT.I'll be using two Melco fiber optic boxes to isolate. Does anyone know if there is a glass cable made that will work with the Melco? I would like to get rid of the plastic fiber optic cable.
As far as I am aware, ALL single-mode fiber optic cable is made with glass fibers.I'll be using two Melco fiber optic boxes to isolate. Does anyone know if there is a glass cable made that will work with the Melco? I would like to get rid of the plastic fiber optic cable.
Australia.I have not heard anything of a a new S100. Could be so but is a newer S100 really needed? The topmodel S10 was realised 6 month ago. Could it be so that Melco will launch something less expensive than the S100?
If a dealer would tell me a “newer model” is on its way out I would wait and not buy the in stock unit. Or go for something else.
In which part of the world do you live.?
Gunnar
I have it. My wife is not all interested in my hobby. As she says “ it’s your hobby and if we can afford it I am ok with it”. When I switched on the S100 / Pink Faun (a radio channel) she looked at me in a strange way and said. “I hear the difference. A big difference “. Prior I had and still have an EtherRegen with a Farad Super3. A really good switch. But with this version you need two power supplies 5 and 12 volt. So two power cords.There's a bit of talk in this thread and other forums about the s100 with the link faun clock upgrades; has anyone heard the s100 with their capacitor and clock upgrades?
One is a bit more obtainable than the other.
Thankyou
Thank you.I have it. My wife is not all interested in my hobby. As she says “ it’s your hobby and if we can afford it I am ok with it”. When I switched on the S100 / Pink Faun (a radio channel) she looked at me in a strange way and said. “I hear the difference. A big difference “. Prior I had and still have an EtherRegen with a Farad Super3. A really good switch. But with this version you need two power supplies 5 and 12 volt. So two power cords.
Not correct. I bought everything from Pink Faun including the two Super3. Pink Faun sourced the S100 directly from the BeNeLux Melco importer and the two Super3 directly from Farad. So one invoice and one delivery. Two years guarantee.Thank you.
My understanding is that s100 needs to be purchased separately and sent in for the modification is this correct?
I ordered my S100 with mods directly from Pink Faun….Thank you.
No, but I am really interested in the answerHas anyone compared ADOT with this Sonore opticalModule Deluxe?
They seem to be doing the same thing.
I have had ADOT with Plixir Elite Balanced LPSU on extended home evaluation for the past couple of months.Has anyone compared ADOT with this Sonore opticalModule Deluxe?
I will await your findings.I have had ADOT with Plixir Elite Balanced LPSU on extended home evaluation for the past couple of months.
It takes an ethernet feed (Sablon 1m) from a TP-Link AC2800 router (12v LPSU-powered). The supplied 1.5m fibre optic cable from the ADOT feeds into the SFP in the Uptone Audio EtherREGEN, then the 'B' side carries another 1m Sablon Audio ethernet cable into my dCS Vivaldi Upsampler/DAC. The EtherREGEN is "reclocked" from a 75Ohm output on my Mutec Ref 10 SE-120 reference clock and powered from a 12v Coherent Systems QP1 LPSU.
Yesterday, I learned that there was UK stock of the new Sonore Optical Module Deluxe, so I have ordered one, together with an order from Mouser.co.uk of the After Dark-recommended Finisar 508-FCBG110SD1C01 1m fibre optic assembly (the FO cable is integral to the Finisar SFP's on each end.
When they arrive, I will carry out some comparisons, firstly, with the Sonore Optical Module as a direct replacement for the ADOT media converter and then with the Finisar cable and SFP's placed in circuit.
