Zero Distortion: Tango Time
DasguteOhr
2,450
2,629
645
Germany
Reactions: Solypsa
Solypsa
1,811
1,401
275
Seattle
www.solypsa.com
Heard these same type drivers last week, same HF horn but different enclosure for woofer ( big FLH from Philips ). Quite nice :)
Reactions: mtemur
bonzo75
22,650
13,685
2,710
London
Reactions: DasguteOhr
kodomo
1,004
1,615
330
Very interesting. I think the setup is not complete. It sounds like it covers 120hz-6khz only.
bonzo75
22,650
13,685
2,710
London
Yes he hasn’t put the subs on. The speakers are still opening up
matthias
1,256
553
213
Germany
I think it sounds quite promising, high noise level though.
Matt
DasguteOhr
2,450
2,629
645
Germany
Maril555
388
346
370
I'm not sure if my experience applies here, but when my Altec 288 were new, I seriously suspected they were deficient, as I had no output over 10 KHz. It took hundreds of hours before they opened up and started to sound like a completely different driver.
Might be the case with Tango's drivers as well.
Bass is pretty much the same story- hundreds hours of playing time before they opened up. Sounded broken in the beginning. Eventually I ended up selling my dual JL subs.
Maril555
388
346
370
bonzo75
22,650
13,685
2,710
London
Tang said they are opening up but Altec 288g/h have higher highs, and the 1 inch like 802g higher than 288.
Reactions: hogen
Maril555
388
346
370
That's what I meant to say. Too early to pass judgements.
bonzo75
22,650
13,685
2,710
London
817 does not require subs. Well, any bass head can add subs, but it excels at rock and orchestral depth without subs. Because of the design of the 817 cab it is ideal for a 2-way that completes the spectrum, with the purity of a simple first order crossover, which now to me is high resolution. Less loss of signal is high resolution. It allows a very simple no feedback low watt amp and pure circuit throughout.
Reactions: adamaley
Maril555
388
346
370
Ditto, But it has taken me some time to come to this realization.
djsina2
1,172
1,018
243
Seemed to sound good at ddk’s so why would they need break in now? Maybe not a good fit for the room?
Reactions: XV-1
bonzo75
22,650
13,685
2,710
London
Let's discuss after subs and some more set up
Reactions: Folsom
