Emile told me that this is the easiest way. Insert the new card using ethernet to the Extreme. Then run the code and once done switch to the split cable as there is a different IP address now and by doing what he said you won't have to search for the new IP address if you sequence the install in the manner he recommendedTo maintain a functioning VNC connection to the Extreme to see what you are doing. The new network card will have a different IP address.
Steve Z
