SOtM sNH-10G Switch : Mods & Tweaks!
If you ease the out slowly from bottom they will come away and you will be able to just slot them back in afterwards. Hope that helps.
Thanks for the tip! Got it out.. now you wouldn’t happen to know the name of this connector?
Sorry wasn’t clear. Not that connector - the JST style 2 pin that connects the wire. Cannot find anything that matches this style in my local electronics store or even online…
Hi @Totima
Are you referring to this connector ?
Here are the part numbers:
Molex 0050375023 (Crimp Housing)
Molex 0008701039 (Crimp Terminal)
Regards
Angelo
Reactions: Totima
Question to sNH10-G owners: do you prefer to take output out of the switch (& into your streamer / renderer / network bridge) via RJ45 or optical out? I know that SoTM does suggest using ethernet out and then a SoTM filter. I'm interested in what the users found via experimenting.
