Breaking news from DCS….
I always issue the caveat that Lamm electronics seem to tame the Wilson metal dome tweeter
Lamm did several shows with Wilsons and the rooms were well received.
Focal tweeter Wilson's I've heard with D'Agostino Momentum amps (such as Still-one has) and other D'Ago gear did not sound bright or harsh in private rooms at shows.
Reactions: Amir and PeterA
Tehran 2007
Reactions: mtemur
here is my SWAG based on my experiences. i've heard Wilson speaker tweeters sound bright, and relatively smooth, but not really all the way spot on butter smooth. and for me this is likely an issue of bass integration, and the various degrees of it happening. Wilson's mostly have 'big' bass, and fast bass, but absolutely seamless bass integration escapes them for whatever reason in my experience. mostly the better bass integration with recent Wilson's i've heard was with the lesser models....just less bass to have to corral. or some nice tubes to cover them up a bit.
with my personal Evolution Acoustics MM7 set up experiences i found that integrating my bass towers after 6 weeks of working at it brought me the smoothest and most extended natural highs i've heard. and it was interesting while i was going through the minute adjustments to the bass towers (which crossover at 35hz-50hz) when i would shut off the power to my bass towers to see whether liked it better on or off i noticed very clearly that the highs were much more complete and natural with the bass towers on and got better and better as i reached the point of complete bass satisfaction and seamless integration. perfect bass overtones complete and balance the highs.
it might also help having deep bass extension and even sealed box bass. my bass towers are -3db @ 7hz and -6db @ 3hz....on paper.
this is not to say that Wilson's are not integrated objectively; it's simply not their best thing, and other speakers are maybe farther down that road. or maybe that Wilson's need a perfect set-up and mature system to find that point.
like i said; this is a scientific wild ass guess. YMMV. maybe i'm dead wrong.
Mike, Thank you for sharing your experience.
I agree you when the bass is ok then we get better mid/high dynamics. I used wilson sub for this test.
This experience is very important, thank you again
I rarely say component x is bright or dark.
What I think is most of the time brightness or any type of awful sound comes from mismatch problems.
I had a friend with this playback :
dCS transport dac clock
Vitus integrated amplifier
Kharma midi exquisite
The sound was bright and I checked the spec and realized the output voltage of DAC is 6volts and maximum input voltage of pre was 4 volts.
The signal over 4 volts clipped and the sound was hard and bright.
Reactions: mtemur
I had a friend who had this system:
dCS Transport DAC
conrad johnson pre power
Wilson watt puppy 7
we changed The speaker position and find a good place with great soundstage, the sound was metalic and forward, we changed the speaker position again and find a good place with great dynamics, very easy to ear and musical.
I do not listen to tweeter or … I listen to music when I want check the system .
Generally see where you are coming from. Having owned the original Wilson X1s and now the XLF which was the first iteration to inspire me to upgrade...for a consecutive 14+ years now, I would say:
- David Wilson's original design goal was to enable his speaker to be adjusted in-room all across the world in different rooms and systems to accommodate room, system and taste
- Each of his upper modules move back and forth, tilt up and down, and have changeable resistors
- So set up becomes either a complete mess, a mediocre experience...or quite an exceptional one
- The key is exceptional is not necessarily about an internalized, fully consistent sound in an of itself...but rather a speaker that is designed to flex around other variables outside of the speaker designer's control
- And so I would generally agree that Wilson speakers are not in and of themselves necessarily the absolute pinnacle in a particular frequency category or characteristic category
- Where I find them really good is that [in the right hands...where here in the UK, Pedro is not only exceptionally well regarded, but where he is flown all over the world to do setups as probably a 'top 5 in the world' according to Wilson] the Wilsons create a great balance of music making:
- excellent level of detail as reflected in how often you can hear minute upstream changes
- excellent macro dynamic scale
- good micro dynamics
- balanced overall presentation which I have been able to settle into over time...where even if, in comparison to a given other system, I notice differences or betterments with that other system...when I come back, I can easily settle back in because the overall presentation does not have any issues which stand out as awkward from the rest
- On bass, I would say that the Wilsons CAN benefit from properly set up subs and in our case, has worked very well in our room with a single Velodyne DD18+ operating below 38hz.
- To your point, I absolutely believe more can be done within the sub-40hz range, and that is probably my next major move...increasing the surface area of sub-40hz cones in the room by several times to create a more effortless, low distortion and ideally more detailed/nuanced sense of venue, and as you say, possibly also creating a better side effect in the mids/treble
On a separate note, I would add that for me, the reason I was inspired to upgrade from the original Wilson X1/Grand SLAMM was not the tweeter and not because it was more transparent or for its adjustable bass port. It was because I felt that it was more solidly built and less prone to losing signal through internal vibration. It just felt like a more robustly designed/built version of the original X1...I came away with the impression that this represented a nicely evolved generation of DW's original design and intentions.
The sound signal felt more solid and more dense to me...like more signal was actually making it all the way thru...and over time I realized I had spent quite a lot of time and effort with the original X1s damping down areas where I knew signal was 'wavering' through the vibrations of the structure.
Even on the XLFs we have discovered that the back of the shelves and main cabinet benefit from nearly 75lbs (35kg) per speaker channel of Artesania mass damping in very very specific areas. But it has responded dramatically more and better than the X1 was capable of with such externalized 'adjustments'.
I would also add that the adjustable bass port (front or back-facing)...turned out to be quite a good thing, as we originally had the X1 bass port (facing back since that is the only way it can), and found the XLF adjusted to port open to front was much more powerful and also far more articulate at the same time.
...but enough...I remind myself this is a DCS thread!
What is the point of a bald statement like this in a subjective hobby?
At least in retrospect there is practically a subjective consensus that the Wilson Audio metal dome tweeters of past eras were slightly bright and fatiguing. I believe Michael Fremer himself does not disagree with this in restrospect.
I don't think there is a need to qualify every statement with IMO. Of course everything that hits our ears is subjective and we base our opinions depending on what each of us is looking for in our set-ups.
This is quite a minority opinion.
Because I am in the minority that doesn't mean I am wrong. :)
I listened to the WPs 7 & 8 a number of times at a dealer who also sold Mark Levinson electronics, which were always paired with Wilsons at their store. I thought an excellent match and a big improvement over earlier WPs. Wilson's inverted titanium dome tweeters were good and not offensive in these pairings. I am an older but probably more discerning listener now, but I sometimes wonder how I'd react today to pairings I really liked back in the day.
Ok, some may find Wilson titanium tweeter bright. I don’t agree but let me ask, do you believe recent silk tweeter is not dull? Doesn’t it have a wide shallow sound, which fails to reproduce transients and never resembles the sound of drum stick hitting cymbals?
IMHO the problem with Wilson speakers has always been the bass, especially double bass drivers not the tweeter.
Reactions: bonzo75
This has not been my experience with the Alexia V tweeter. In fact, I texted a friend shortly after receiving the Waltz for Debby UHQR this weekend about how excellent the brush work was. The Vs create a very natural rendition.
I have not had any issues with the bass on the Vs either. With or without the Loke subwoofers.
That's exactly what I'm talking about. Silk tweeters are very good at brush work on cymbals with wide and shallow sound signature without transients. But when it comes to reproduce drum stick hitting cymbals it falls short with no transient and no bold crash of cymbals.
The dCS Vivaldi DAC output voltage level is user selected. That setup can use the 2V output level, which would not overdrive the preamp.
Reactions: Amir
That's exactly what I'm talking about. Silk tweeters are very good at brush work on cymbals with wide and shallow sound signature without transients. But when it comes to reproduce drum stick hitting cymbals it falls short with no transient and bold crash of cymbals.
So one of my demo LPs for visitors is the Ludwig pressing of Led Zeppelin II. The Alexias have a very realistic portrayal of Bonham's sticks hitting the cymbals.
I believe the reference quality capacitors on the Alexias play a role in the sublime transient performance.
Maybe someone should change the title of the thread. :D
Reactions: PeterA
Might it be that the Wadax production cannot keep up with the demand? Wadax is doing extremely well, believe me.
Sure, you may be right. Do you have any numbers? But again, why haven't the top dealers picked them up, instead of being relegated to the fringe? Surely that would validate their "greatness".
I think Wilson doesn't do justice to dCS (same for audio research, who also get judged by the wilson sound).
dCS may not be everyone's first choice, myself included, but it sounds fine in very musical systems.
And sometimes, it's a "synergy thing": North American avantgarde distributor, who is also a wadax distributor, shows off avantgarde with dcs, not wadax
