The Stabi M looks as low risk a purchase as one could make.
I think I've heard/read that ZYX do. But I could be wrong.Speaking of Kuzma, does anyone know who makes the CAR line of carts for Kuzma? I had heard it was Lyra, and if so, I wonder if the Kuzma line mirrors the commercial Lyra line.
Hi, I have the chance to purchase either a Kuzma Stabi M in walnut ex - dem or a Kuzma Stabi XL - DC used but as new. They are both around the same price! It is impossible to hear them both together though. I am torn between them, so I need some help and advise please. I already have a Kuzma 4 Point tonearm. Many thanks.Hi,
I was fortunate enough, some time back, to find an amazing deal on a Kuzma Stabi M with 11" 4-point. It also came with the periphery ring, which I use quite often. This table is going to stay with me for the long run, and I am glad to answer any questions. I'm also pretty familiar with the Kuzma XLDC and SME 30/12a. All three are phenomenal tables. Vs direct drive, or perhaps idlers, I find choosing really depends heavily on system synergy, room acoustic properties, and most importantly personal preferences. For me, the idlers are certainly finicky and easy to make sound unenjoyable. I've heard Garrard 301s sound absolutely relentless in certain rooms with certain systems, for example. The Technics DDs can be quite good, but again for me, tend towards having a bit too much leading edge and being a tad mechanical rather than musical. With my Stabi M though, I do find very expressive, dynamic carts to be a great fit. I use the Transfiguration Proteus. The overall sound oozes detail in layers with a holographic soundstage and well fleshed out instruments. There is just an overall ease of presentation about it that is so natural. As trite as it is to say, I just get lost in the music.
Last point: I can not agree with the complaint about Kuzma build quality. I've never heard anyone even suggest Kuzma build quality was subpar. In fact, the Stabi M is built like a tank. Literally. The 4 point is an extremely precise set-and-forget arm than extracts more detail from the grooves than just about any arm you're going to find. An absolute joy to use, listen to, and built to last three lifetimes.
Good luck!!
Hi Again,Hi,
Good luck!!
I can give you my impressions on the M vs XLDC if it'll help. I've heard both extensively. PM me.
OK, in what way is it better?M is better than XLDC. Possibly suspension plays a role in this particular thing.
OK, that would be great thanks.I can give you my impressions on the M vs XLDC if it'll help. I've heard both extensively. PM me.
