Well, I'm home right now, everything back on, was enjoying some music, and then a huge dip in the power- sure, i see the effects of an AC compressor kicking on normally, because the lights will dim momentarily, but this threw everything into standby mode-it was like power to the entire system disconnected momentarily, although no breakers tripped, and everything resumed/power lights came back on in safe start mode (that's how the Lamm stuff works anyway, if you power it down, you have to wait a couple minutes for it to come on again). Kinda freaked me out, because that's never happened during a listening session in six plus years here. Power company said no scheduled work was being done on the line but acknowledged that, given the heat and humidity, we could be borderline in terms of 'brownout' conditions. I didn't measure the voltage at the wall, and suspect if I did now, after the fact, it would probably read fine. The utility person also said that there is line switching that occasionally occurs as a protective measure if a squirrel gets into the wrong place~ I'd hate to think of what happened to the squirrel, although I do like BBQ.
Maybe I just need my own power plant.
