I've not tried the Thor SE Master Reference ground cable on the Silver Tellus.....or mixed any of the other Tripoint and Entreq cables.
I know what happened when I installed my Tripoint Troy with the Thor SE Master Reference connected to my dart preamp. I already had a Silver Tellus connected to that preamp with a pair of Eartha Atlantis RCA's.
i'd say that the degree of improvement compared to what the Silver Tellus-Eartha Atlantis had brought by itself was at least as much as the 5 to 1 cost ratio. quite amazing. and that was right out of the box stone cold. about 10 days later it took another step up about 2/3rds of the original jump.
both products work.....and are performance boosters.
i'd also point out that these type products are quite context dependent. whether other systems would have the same reaction as mine to either product is a question. my system is about as tweaked as can be, and it's noise floor is very low as well as the top level darTZeel electronics are very very quiet. so everything these products can do is easily heard. when I describe degrees of perceived performance change it's only my own views in my own system.
Thanks Mike.
Yes I agree and my earlier comment was about cost effectiveness and not any animus to Tripoint.
It also struck me afterwards that what I suggested was not entirely accurate as separate ground boxes are needed for negative speaker terminal grounding so you would need another Poseidon or two of the other ground boxes.
More out of curiosity than I suspect any practical application I presume that any negative speaker terminal grounding would need two boxes be they Entreq or Tripont.
