Ok, finally I can share... around the first of July I finally, after almost daily sleuthing for almost 6 months, I was able to find and buy a used Etsuro Gold. I won’t get into all the murky details but there was a bit of an issue that came up and just finally got resolved. Just as that little saga was coming to a close, my preamp popped a small cap in the power supply. Preamp fixed, Etsuro Gold mounted up and painfully tweaked with Adjust+.
My AMG 12JT “turbo” tonearm has a design flaw (IMHO) in that to adjust VTA you have to loosen a thumbscrew then retighten when you’ve reached your preferred height. But, tightening the screw ever-so-slightly changes the angle of the tower so to get good readings one has to loosen, adjust, tighten, measure. How much you torque the screw effects the result.
I’m a bit anal about such things, and being pretty much a rookie at cartridge setup, I took my time. I got azimuth spot-on then adjusted for VTA which improved crosstalk buy almost 2 db. Then I re-tweaked azimuth.
Did I mention that after visiting Mike’s place a couple times to hear his Gold stash, I chose to replace my Einstein phono stage with CSPort phono?
Long buildup, I know... but holy shit! Brand new phono stage (battery not even fully charged), new tubes in the preamp, and an Etsuro Gold with fewer hours on it than broken in. To give you an idea, its well past 2am (I’m too old for this kind of late night tom-foolery) and I had to shut things down. Not because I want to. There is just sooooo much more information, nuance, subtlety i am hearing compared to the Benz LPS that has been in my system for half-dozen years.
I’ll just say with the shit-storm that has been 2020, it is really great to have a positive development. Hats off to the gentlemen-san @ Etsuro.
