They were thinking July shipment, so I am guessing September the way things go.That's Too Funny Bunny!! I think "dear old Dad is raising you right and giving good advice". Any potential time frame with the arrival?
Hi, I need your help. I have to decide purchasing Apex stereo or Mephisto solos. Gryphon brochure and on line web page shows Apex seems better or equivalent to Mephisto solos and slightly cost less On the other hand, Mephisto is still a proven and beloved mono amplifier although it is 8 years old design.
I am on the market to purchase my new amplifier and would appreciate your comment and advice for right decision,View attachment 89737
Hi John T,LL21 I saw on a previous post in which you used a Torus Wall Unit with Mephisto. I'm concerned perhaps the Mephisto won't like this? I spent a good portion of the day yesterday polluting my brain with more stuff. I see Equi--Tech is mentioned a lot too. Can you elaborate more on the advantages/ benefits/sonic improvement with going in this direction? If I go down this road I would have a 2nd meter/subpanel/ground/for independent power coming in solely for my audio. If I feed from existing panel it will be approx. 60' run, I can shorten all runs to well under 10'. I would then install a Lyncole Grounding System, primarily they ground for large medical equipment. Anything you can share will be greatly appreciated. All The Best...
John
not heard everything. but the dart 108 Mk2 is my second favorite amp of all time. only to the dart 468's. you buy those and forget about electronics. just listen to music. they do everything that counts. and you don't need to balance them with anything. just get out of the way. and they have real world flow and immersion.Odd that they copied DartZeel - couldn't Gryphon have selected a different color for the caps and bus bars?!
My 2c: get more efficient speakers and get the DarTZeel equipment - they are unprecedented, nothing really comes close.
Sounds like a great setup! I do know people who tried the Robert Koda K160 Monos (230 watts Class A into 4 ohms so something 1100 watts out of the wall at all times)...and while they liked AVR16...they found significant benefit running 2 x AVR16 (7.7kwatts) and I think decided to go 10Kwatts.L Thank You for the input. I take it you are in Europe because of the AVR? I'm looking at the wall unit WM 100 Bal, and perhaps the RM 15 to separate the digital front end? The WM 100 has 5 circuits and there is a way to add, with another smaller panel, more circuits. Need to find out more on that. What I will do is have the power company run an independent cable to a separate meter that will feed the WM 100 Bal, with a separate grounding system. (Lyncole) They typically do very expensive medical equipment, but they have done work for recording studios. Waiting to hear back from the county inspector. No problem with my power company. This will provide me with a completely independent power for my audio with no influence from my existing panel. Insanity!
Big project...big amp! I suppose reading your description, this is basically a super-giant version of the Entreq box which is mineral mix in a massive box...we are currently trialing some large boxes of them...220lbs worth. In the city, you cannot just go out into the sidewalk and dig a hole! And if you are in a highrise...its even harder to imagine!Thank You, lots of stuff to take into account. The Lyncole grounding system can be done vertical or horizontal. The preferred method is vertical. 10' deep hole, I would have to get a friend who is a well digger to drill a hole. This isn't a typical 5/8 copper rod. They recommend a 36" trench for the 4awg wire to connect. On top of that the wire is encased with ground enhancement material and the hole is also filled with the same enhancement material. Oversizing everything to accommodate APEX or any potential larger draw of power. I have this system dialed in now, hard to imagine a much better presentation. Big project!!
The enhancement material is mixed with water so when it is poured into the hole and trench it encapsulates the rod and wire feeding the rod or electrode. It then hardens. With the 4awg wire feeding the rod one would put spacers under the wire so the enhancement material surrounds the wire. Its actually bentonite along with other "special sauces". Magnesium Sulfate does the same thing but it eventually washes away. One vertical rod done right should achieve a consistent resistance, but seeing that you have 2 already installed, I would bridge them together. If you do bridge them I would advise having the wire making the bridge also encapsulated with the enhancement material. I don't think you could achieve any better than that. Ron was your electrodes or rods from Lyncole? When I spoke with them only 6% of their business is audio related, all the rest is medical equipment.
Hi - I am no techie. I simply know what I hear. As for internal to the box, I believe there is silver, copper, some kind of minerals as well as more recently Tungsten. Other than that, no idea. All I know is that it works. Having taken it all out and put in the new one, it is a stiff sounding system again in comparison...bit nerve wracking. But that is also what happened the first time as it became more and more nuanced, supple and naturally filigreed across the board even in deep propulsive bass.L what is the mineral composition in the box? For the Mephisto I would need a box car from a train filled with minerals! Entreq, also Acoustic Revive has these products. I think grounding with this approach is technically different than Panel/Meter grounding with Rods and such?
