What I have gathered is constant ground resistance is what you are attempting to achieve. Not so much the number. Sure if you can get 5ohms or less that would be great, however with most substrates not possible. This is why enhancement material is used to obtain consistency. Weather, temp., a host of factors influence ground resistance. Who in there right mind devours everything they could find on Grounding? An Audiophile with OCD!!
Yes, although we have moved on to a trial with Entreq (Tripoint remains on 4-box Zanden and Torus...but the Entreq on Robert Koda, signal and sub is proving intriguing...more to come...
Thanks Lloyd, I've looked at both Torus WM 100 Bal and Equi-tech, quite frankly I'm overwhelmed! I'm attempting to isolate main power supply and then tweak later.
I honestly cannot speak to Torus vs Equi-tech....my sense is both are awesome at what they do. Could hardly think you would go wrong with either...more about which model of either you choose.
Very different units. The Equi-tech is a balanced output mains, the Torus output is not balanced - they dislike the idea - and includes a very well thought unique filtering system that cancels noise and distortion in shunt mode, not in series as the usual filters.
I have no experience with the Equi-tech and the choice surely depends on gear, but unless a system is very complex and includes many components I personal lean towards the Torus.
One other thing the Torus is balanced in. I spoke with them last week and that is how it was explained. I'm waiting to to find out if the county will allow a 2nd meter.
I only compared Mephisto with my Antileon, and in my room with my speakers I like the Antileon more. Mephisto more transparent but a thinner sound. Antileon warmer and fuller...a better match for my Tidal speakers.
I never compared those two, but in general audiophiles assume the later or higher priced model is better. Sometimes, especially for brands that have been around a long time, it is not so straightforward. Some models and some years have been better for certain brands and some years could have produced less good sounding, or at least different character products. Some times due to becoming more cost efficient/higher margin, some times due to change in designers. So it makes more sense even in a line to check for different models. It is always good if you preferred the lower priced one.
Congrats...I have heard excellent things about the 'new' Antileon. I have only heard/owned the original. I know a few people who also preferred the new Antileon for its recreation of the event.
Probably the Mephisto is more neutral, but I was a tube guy, and when I decided to go to a SS Amp, I made a criterious research and ended with the Antileon...is like a 300B amp on steroids....fantastic IMO.
I think when Gryphon moved to the Colosseum, it illuminated the treble in a way I really liked from the earlier Antileon. It was a treble in keeping with the Gryphon house sound. Then came the Mephisto which was a further advancement in that same direction. However, I also had heard many still have love for the original Antileon...but now with those advancements, I suspect they have managed to create an Antileon sound that could present the detail and luminesence of treble but in a more '300B way' as you describe. That is fantastic and pretty much I suspect exactly what they were aiming for at Gryphon. i wonder where the Apex sits in voicing.
