ack,
I'd like to provide some answers to your questions and convey more information about semis. First off, you made a very good point about designer-design-sound priorities, I will elaborate on this later.
Going back to SemiSouth SITs, the fundamental theory goes back to the mid '70s and was developed by Dr. Jun-ichi Nishizawa in Japan. Devices developed in that era were made of Si (silicon). A SIT (static induction transistor) is actually a JFET on steroids, a normally-on power device. JFETs, the very few left, are typically small signal devices. SITs were made for high frequency power processing, back then like today. The BIG differences between legacy Sony and Yamaha devices and the new SemiSouth devices are material and mode of operation. SemiSouths are made of SiC (silicon carbide) to take advantage of the material characteristics: breakdown voltage and operating temperature are higher than is achievable with Si MOSFETs, FOM (figure of merit) for Rdson and Crss is also advantageous. This makes for a device that run faster at higher frequencies, voltages and temperature. SiC made possible another major breakthrough: a normally-off SIT. You need to apply voltage to the gate to turn on the device (current flows between drain and source). This is a huge advantage in power applications as it makes control circuitry much easier and intrinsically safe. But I digress, just wanted to point out that SIT1 is in no way a replacement for 2SK and 2SJ legacy devices. Those are long gone and only available as NOS (new old stock), until they last. There is another subtle but fundamental difference between the old Si parts and the SemiSouths. The marketplace. Back in the '70s audio WAS a mainstream market (for power devices) and companies like Sony and Yamaha could afford the expenses of developing devices optimized for linear operation. This is not going to happen in the new millennium. Sad but true. Even then, one of the target product for those devices was a switching Class D amplifier (Sony). It was just too ahead of its time to be a commercial success (today could be different with the mobile revolution). What happened was the Si MOSFET became a commercial success thanks to International Rectifier and the industry made his decision (remember the normally-on feature of SITs? Not good.). The rest is history. There is ONE family of lateral MOSFETs developed by Toshiba (now sold by Renesas, until they last) that where specifically developed for audio but, again, it is a few parts against literally thousands of parts made for switching applications.
So, are we really at the bottom of the food chain?
Yes and no!
Linear amplifiers, preamps, power amps? Yes. Do not expect anything new from the semi industry. Have you noticed that even the SemiSouths are only available as N channel? N and P complements like the old Sony and Yamaha SITs? A time machine to bring you back in the '80s is more probable than Toshiba, or maybe Samsung? making one of those today. Use what you have, there are plenty and they are good enough (not the best though). Period.
Digital, DSP and new software and interfaces will be the focus of the semi industry for the years to come. Audio will be much different for the better. Product differentiation will be on software rather than hardware. Think about it, why is my old iPhone 5 so much better than my daughter's Moto G? (Don't want to start a iOS / Android war here
just compare the hardware specs of the two devices and their street prices).
What I said is the key to understand why the designer-design-sound priority is so important. Nelson Pass and KOJ were there when all those great devices were available. And they were doing audio designs with them. The experience the made is invaluable if you are aiming for the best. Most of the tools available today are so much better. But who knows how to use those tools for audio design? How do you teach experience?
And, back to ack's questions, whether the SIT1 is actually a custom part or not is a matter of semantic. Take a standard part, laser mark it with your own P/N and it is no longer a standard part. This was done with the STASIS N and STASIS P power transistors for instance. Difference between the STASIS N and a Motorola MJ15xxx? The name. Issue an SCD (specification control drawing) and a standard part is tested to your specifications. Lower tolerances for instance, was this the case with either the STASIS parts or the SIT1? Possibly.
And, have I seen the SemiSouth SITs in other brands? No, SemiSouth went south before that could happen and, BTW, it would have happened only for boutique products. Remember the lack of complements, no P parts? Audio power amplifiers are usually push-pull. You need to be Nelson Pass to make a single ended solid state amplifier attractive on the marketplace. It's marketing. This is a fashion industry, well... mostly
If have come this far you understand what I mean.
I don't have a good answer for the "custom semiconductor technology developed for high resolution display". I haven't seen the video yet. Will come back to this later. In any case, I remember Pioneer using high speed BJTs drivers in their best power amps. But those were the times when high resolution displays were cathode ray tubes. High speed, high voltage BJTs were ideal for that application. I'm talking about 25 years ago, maybe.
Enough for now. I'll go to see the video.
Have fun.
