I know what natural is but what’s a freakin plane ticket? We can’t even drive from state to state here lolSo, plane tickets to expensive systems that are not natural will help understand the contrast better
Tang, in case you are not following this is what some googling gives you
What does it do? Well, it controls “presence", which boosts upper-mid and treble frequencies in a specific manner that makes the tone sound notably livelier; a little “wilder” than normal. The quality of this livelier, wilder tone is typically described as being more “present,” thus the name.
Saying that the upper-mid and treble frequencies become more present doesn’t exactly mean they become “louder” in the sense that an amp’s volume control affects all frequencies evenly. Nor does the presence control affect the tone in the same manner as the amp’s “mid” and “treble” tone controls.
To explain what a presence control does in greater detail, let us note a fundamental basic of amplifier design. Namely, that an amp consists of at least two “sections”—a preamp stage and a power amp stage. The preamp stage comes first and is where most of the tone shaping happens; the power amp stage comes second and provides the muscle that blasts your sound out into the world and makes the neighbors call the cops.
Your amp’s traditional tone controls—“bass,” “mid” and “treble”—reside in the preamp stage and thus accomplish their work before the signal reaches the power amp. These tone controls are generally “subtractive”—that is, they don’t boost anything; they control the amount of frequency band removed from the signal.
The presence control, on the other hand, resides in the power amp stage. Technically, it’s a “high frequency shelving boost” control, which is much like the treble control on a traditional stereo. Turning it up actually does boost part of the frequency band.
Here’s where things get a little complicated, but hang in there with us. Because of the nature of power amp design and function (specifically power amp feedback, the science of which fills volumes if not entire libraries) the presence control affects upper-mid and high frequencies in a completely different way that than the normal tone controls found in the preamp stage.
Increasing the presence control decreases high-frequency-only feedback in the power amp, which makes the amp distort more easily for higher notes. Also, it decreases the amp’s ability to precisely control the actual speaker cone at high frequencies—this is what makes the amp sound wilder and raspier in a way that the treble control knob isn’t capable of.
When playing an amp cleanly, increasing the presence control simply results in more upper midrange and treble.
When pushing an amp into distortion, though, the presence control behaves differently. It changes the “texture” of the distortion and adds complexity to the sound, making the amp feel a little “less predictable” for higher notes.
As you can see then, the function of the presence control varies with volume. The louder you play, the more it does and the more noticeable it becomes."
What you’re quoting here is a type of eq used in PA and sound reinforcement systems, similarly named controls, ie “presence & brilliance” were available on some vintage speakers like Tannoys which basically rolled off the top end or changed the sound balance to emphasize certain frequency range. I doubt that any reviewer is trying to describe sound in eq terms.
david
You’re reading too many reviewsI did read in a couple of reviews talking about the presence region, as if it was a frequency range. That is what confused me. I don't know which reviews now as it was a while ago. If someone just said I felt the presence of the singer/orchestra, that is much more easier to understand in a holistic way
Is there more?
Surely.
See https://www.stereophile.com/reference/50/index.html . It is all there.
For example,
naturalness : Realism.
presence range The lower-treble part of the audio spectrum, approximately 1-3kHz, which contributes to presence in reproduced sound.
Some people use too much brain hearing sound and scrutinize too much of everything. Presence is just presence. You could hear and you could feel otherwise your brain wont be triggered to come up with the word "presence" to describe the sensation. My secretary knows no audiophile vocab yet she used the word presence to describe sound to me once. So no need to act like such a guru that can no longer use a simple word such as "presence" or "natural" to describe sound.
No, we do not. We need season tickets to a great orchestra, or a local jazz bar around the corner, invitations and plane tickets to visit Tang, ddk, MikeL, or others, and a reliable memory.
Surely.
For example,
I stopped reading some replies on subject. So long, but just trying to justify philosophy for purchase/setup belief.
I think we rarely need to justify. However, When asked what led one to the recent changes in his system or “Did you have a revelation?” would you prefer to read a simpler response such as “ I bought it or I did it because I wanted to“?
I suppose such a response would be kind of refreshing.
See what? That turning the knob one way boosts that frequency range and turning it the other way changes the balance in another way? Personally I don't have a problem with the word and probably can understand the author's intent if I read the review, which I rarely do anymore.See David? 1 - 3khz
Then we can shut down the forum.
Writing should be treated as a sport, so please turn up to play
david
I meant see, this is the review that was trying to apportion a frequency range to a word like presence
But like a scene from Oliver, I am tempted to say again can I have more. Not rudely or because I am greedy but (while containing some great and handy stuff) none of the systems of subjective definition that have gone before have actually answered all our questions or satiated all our hunger to understand better.Surely.
For example,
