I agree, fuses are a way to tune the sound signature and are a very personal thing. If
@Kris has 45 fuses to replace, that would be an expensive proposition with even a $20 fuse let alone a $200 fuse. If somehow, you prefer the inexpensive Schurter fuse over a much more expensive Synergistic Research fuse, then you've really struck gold.
I think just as important to Emile as SQ is reliability and he touched on this already. I can imagine the headache he would have if he had to deal with lots of support calls for Extremes that won't boot up due to a blown fuse and many audiophile fuses, especially the SR fuses, are prone to blowing which is why many (including myself) choose to slightly uprate their fuse (which opens up other issues). I received a new power supply some months ago and with this power supply, I did prefer the signature of an SR Blue fuse. Anyway, while turning on this power supply after having left it off for the weekend, as the capacitors had fully discharged, upon turning on the unit, there was a massive inrush of current that ended up blowing not just the Blue fuse in this PSU but 2 other Blue fuses, a Black fuse, and a Beeswax fuse in other components that were on the same circuit. Basically, a very expensive setback. What is interesting is that a preamp that I was testing that was using its stock "inexpensive" fuse was the only fuse that did not blow. Even if it had, obviously, it would be no big deal to replace a $2 fuse. Somehow, audiophile fuses are very fragile.
With that said, I have been testing the latest Orange fuse at
@isquirrel's recommendation and with every component I have placed it in thus far, I have liked what I've heard and this has rarely been the case. As some have suggested, the Blue can sound a touch bright and the Beeswax can sound a touch too warm and even slow and so it ends up becoming a balancing act. The Orange, to my ears, is much more neutral. I hear excellent extension but nothing that is exaggerated and somehow, it very nicely balances performance (especially better detail layering) and musicality.
Some months ago, I purchased a large number of CenterStage2 footers manufactured by Critical Mass from
@Steve Williams and while I have not yet tried the Panzerholz footers and Daiza platforms that Emile makes and sells, I have found these CS2 footers to be incredible, better than anything else I have tried thus far including the HRS Vortex and anything from Stillpoints. They are very neutral (meaning they are evenhanded in their noise reduction) resulting in very noticeably enhanced resolution but they also provide this immersive "creaminess" to the presentation that is very difficult to describe resulting in what I would consider to be an excellent balance between resolution and musicality. The Orange fuse reminds me of these footers and so undoubtedly, I will give the Orange a try once my Extreme arrives.
Here is another thing about audiophile fuses, especially the SR fuses, that leaves me scratching my head. According to SR, every time they come out with a new fuse, compared to their previous generation fuse, their new fuse is now supposedly so much better it will cause you to weep uncontrollably and to soil your pants. Yes, it's exaggerated marketing but somehow, there is truth to it and I always wonder how much more a fuse can be improved or is it really being improved? Is it possible that these audiophile fuses, as Emile has suggested, are losing performance over time so that when SR's latest fuse comes around, the new fuse seems to be a significant improvement when really, it's because the older fuse has lost performance? Perhaps, I should buy an Orange fuse and tuck it away and compare this against the Green fuse (or whatever SR wants to call their next fuse) whenever it is released in the next 12-18 months (that seems to be how often they're releasing new fuses).
