No need, Alpha testers will be automatically on the Beta listI hope the move was uneventful. The new digs look awesome
Ed do I assume alpha users become beta users or do we also need to reply by email
Egged on by Emile last night, I purchased and downloaded a Louis Armstrong and a Sarah Vaughn DSD 256 album from High Definition TapeTtransfers, and Wow, I understand what you are talking about
Reviewing the sonic data points we have collected, it would seem that TAS has unleashed DSD and Hi Res to a new level. It’s good for us to know that Qobuz now sounds pretty much the same in the USA as it does in Europe at this new higher level.
With the feedback that we have received we are now drawing up the road map for the Beta release
- an implementation of Gapless playback which can be selected from the XD settings screen
- larger buffer size choices for 16/44
- Play list pause actually works already
- time elapsed display ( we are not sure about a play progress bar)
- display of bit depth and sample rate in Album display and on playing screen
- more integrated / less complicated installation
-Button in App to call for customer service button which will send an email with logs to Taiko
The target time of arrival of the Beta is the end of the year. In 2 weeks time, I will ask for Extreme Owners who are interested in receiving the Beta to send us an email with their Extreme Serial number
A big thank you to all of the Alpha testers for listening and then writing at length, no way we could have made this progress without your time and support
Emile has turned off the lights in Hengelo for the last time this evening, and all the gear is now in Oldenzaal.
A random play feature that starts (when enabled) after the last track in a queue has played, which plays somewhat loosely related (by genre) selections from Qobuz and Tidal and stored music. This is one of the big features from Roon I like for discovering new music or reminding me of music I already have but haven't played for too long.
I'm still learning my way around all the TAS functions. I haven't figured out if there is a way to set up, name, and save a variety of permanent playlists right now in TAS (that would be a "must-have" feature to consider if there isn't, IMHO), and I'm not sure what the "check box" feature in TAS is supposed to facilitate. (Hint, hint -- in all the spare time you guys have, a more extensive quick start guide to TAS would be helpful). Still, I would say that anyone familiar with a basic digital player app will find TAS very intuitive to use. There are some pretty sophisticated features just below the surface, and clicking on all the buttons in each screen is very instructive.
Besides a way of enabling gapless playback by album or queue, at some point I'd like a Search function for My Music that looks for matches to terms such as Artist or Group name, Album name and/or Track (song) title. With over 60,000+ tracks in my music library on my Extreme a search function would be very helpful.
I'm an Extreme owner but not an Alpha tester, nor should I be, but I have a question: what are "superscript special characters"?
Austinpop,TAS Alpha Feedback
I've had the TAS Alpha installed on my Extreme for a few days, so here is a listening report. I won't focus on bugs/quirks here — this is alpha code after all, so these are to be expected, and I have passed them along to the Taiko folks. There are use cases that fail, and that's fine. This is alpha code.
I'm coming at TAS from perhaps a different perspective than most Extreme users, as I'm not using Roon as my primary music player. I've already vented about my frustration with the SQ of Roon, both here and on AS. Before I got an Extreme, I had abandoned Roon on my previous platform (Euphony OS) for Stylus. I also found that my constructive feedback to Roon to improve their SQ was rebuffed due to the trolls that inhabit their forum, the only mechanism via which they accept feedback.
That said, I readily admit that the UI of Roon is head and shoulders above all other music players, so one of the factors that drew me to the Extreme, thanks to the persuasiveness of my friend @romaz , was the prospect of returning to Roon, with all the SQ magic that Emile was able to extract. Sadly, as we all know now, Roon's updates earlier this year derailed that dream, and was one of the forces that impelled the creation of TAS.
For myself, I switched over to using HQPlayer 4 Desktop in a standalone fashion. I have found HQPlayer feeding NAA to run circles around Roon in SQ, albeit with a clunky interface. The control app, HQPDControl gets the job done, but certainly is not the slick UI that Roon is. This is what I use for local files. This also allows me to literally unplug the network from the Extreme during playback, so this is a blessed removal of that whole can of worms (of network switches and cables) from the mix. And the SQ is glorious!
Where I do still use Roon > HQP/NAA is for playback of Qobuz material. So for me, my hopes for TAS were primarily to improve my experience with Qobuz streams. Any improvement over HQP standalone I would consider icing on the cake, but not critical.
Note: in all of the above, I am using the sinc-M PCM upsampling filter in HQP/NAA. I also have some upsampled files that I play natively, and on HQP/NAA I do this by setting filter/dither set to none.
Once I had TAS Alpha running, my primary comparisons were:
Findings
- Qobuz source files
- How does TAS > HQP/NAA compare to Roon > HQP/NAA?
- Local vs. Qobuz
- When using TAS > HQP/NAA, how is the SQ of Qobuz files compared to identical local files?
- For reference, Qobuz > Roon > HQP/NAA sounds much worse than Local > HQP/NAA of the identical file.
- Local files
- Compared to HQP/NAA standalone (fed via drag-n-drop or HQPDControl app), what is the SQ of:
- TAS > XD
- TASP > HQP/NAA?
- Just out of curiosity, how does TAS > HQP/NAA compare to Roon?
Let's cut to the chase. TAS wipes the floor with Roon. It then takes it out to the woodshed and gives it a pasting. Compared to TAS, Roon is barely listenable. The aspect of TAS I am just overjoyed with (SQ only — functionality still needs work. Did I mention? This is alpha code) is just how good Qobuz files sound with TAS > HQP/NAA. Compared to the same file played locally, I would say Qobuz on TAS is about 95% of the SQ. It's that close.
How did TAS > HQP/NAA compare to HQP/NAA standalone? So far, I'd say it's neck and neck. TAS has a more relaxed, natural, and organic presentation, while HQP is a bit more exciting, dynamic, and incisive. At the very least, it's very close.
What about TAS > XD compared to TAS > HQP/NAA? Again, it's very close for me. For those who do any kind of upsampling in real time, the HQP/NAA path is necessary, but if you have files that you can play natively, I'd say TAS > XD was very close to TAS > HQP/NAA (pass through).
Final Thoughts
Emile and co. have really got something promising with TAS. As you'd expect from anything Emile produces, SQ improvement is at the heart of TAS, but I also expect the planned functionality improvements coming in the beta to make this a very slick to use player.
I know I said I wouldn't talk about functionality, but I did want to say that as a classical music fan, gapless playback is very important to me, so I'm glad to see that Taiko have taken that on as a feature requirement for subsequent evolution of TAS. A traditional symphony or concerto has discrete movements, so a pause between them is not bad. However, there are other styles like operas and oratorios, where the piece tends to be broken up into recitatives and arias, that are on separate tracks, but they flow together. Long gaps between each just isn't a satisfying listening experience.
Keep up the good work, Emile, Wilson, and Ed, and looking forward to the beta!
All of this reports are so enthusiastic!Austinpop,
Many Thanks for your report and analysis
When you add up your time and effort, system cost with that of the other Alpha testers, we could never achieved this level of system testing and validation alone.
For me a big takeaway is that we seem no have no streaming SQ difference between USA and Europe anymore. It’s something we have been pondering for 4 years, and now we have found and implemented measures to effectively fix that
On my to list for todayPlease post the pdf of TAS quick start guide
Thank you, Ed. I've replaced my original Quick Start Guide with this latest updated version.Here is the TAS and Extreme Direct quick start guide
Thanks so much Edward~!!Here is the TAS and Extreme Direct quick start guide
Thank you Steve for keeping us educated with TAS in „Taiko Neverending University”My final caveat..
TAS was inserted 8 days ago in my system and since that time I have not listened to Roon once orher than to verify that I could change from one server to the other
I would recommend you all take Emile up on the offer to be a beta tester. You won’t regret it TAS is the real deal
