Hope this little DIY-detour was ok
I felt like I needed to chime in here
What is worse is that I will need a PCIe riser cable to fit such a large card in my chassis
Yes I know...
The Taiko DIY chassis is rarely mentioned on this thread.
https://taikoaudio.com/taiko-2020/product/diy-audio-server-chassis/
I would highly recommend to people who are planning to use the PCIe TACDA/TACDD card to consider moving their DIY server to the Taiko chassis. Yes, the chassis is not cheap but the quality is exceptionally good. No comparison to HDPlex, Streacom, etc.
You will benefit from:
a. Extra space inside. Also avoiding the PCIe riser cable.
b. Lower temperature, which believe it or not has a significant sound impact.
c. Excellent vibration properties. EMI/RFI as well...
Given that this chassis will be your server AND your DAC, it should be worth spending some extra money to get this right.
I would not know until I try it, but I have a feeling that a PCIe riser cable may kill a lot of the performance of this DAC card.
Powering the TACDA has been mentioned I think. Here comes a DIY-oriented approach. I could feed it DC from the Taiko DC DC ATX (SATA) or from Sean Jacobs 5/12V rails. How will it best be fed DC (externally)?
As far as I am aware there is no space for external power connectors to be routed to the outside of the chassis. Fitting RCA, BNC, Toslink, etc takes all the space on this card already.
Expect to have a Molex connector on the back just like the Taiko USB card. Extreme users will connect it to the auxiliary GX16-4 pin power connector, where they connect the USB card currently. I read somewhere that a Y-connector will be provided in case you want to connect both (the USB card and the DAC card).
Those who use the Taiko DC-DC ATX can use it's SATA output connection for the DAC card. That has a pretty good quality separate +5VSB rail and a shared +12V rail. How good those two rails perform depends to a large degree on the quality of the power supply feeding the DC-DC ATX (an unregulated LPS for most people I hope). But they are better than many aftermarket linear power supplies.
You can get an improvement with a high-end LPS, but that would mean mixing up grounds of multiple power supplies which may have some negative impact. I will be making those experiments for my own system and will be happy to share my findings.
The DC-DC ATX (SATA ouptut) will probably be good enough for most people.
And not to forget, the beauty of the Taiko BPS will be to lift the entire digital source (router, switch, Extreme, and DAC) off the grid!
(I ask since for example PF is more AMD-oriented and some of their cards seem to have issues with Intel. And since the Extreme is Xeon based I wanted to check AMD compability.)
PinkFaun uses the C-media CM8888 chip, which was not officially supported on ALSA when I used it (3.5 years ago). It worked on some Linux distributions but it had issues with certain Linux distributions and some hardware. As far as I know the developers of C-media were just not interested in the very small high-end market, and they never fixed the issue with some Intel CPUs. That might have changed in the past 3 years, so don't take my word for it.
Taiko has in-house expertise when it comes to writing / tweaking drivers, and so I don't think we'll run into that with Taiko if they decide to add support for Linux. And it seems like Emile is willing to do that. In fact, I have volunteered to help with testing/listening to the Linux driver. I miss some of that digital-source DIY fun!
