Unsighted you wouldn't be able to tell the difference, Ivor famously couldn't in 1981, and digital processing has advanced enormously since then.
Keith.
Ivor Tiefenbrun of Linn?
Keith.
Rodney, as a died in the wool analog man, I've just had a VERY interesting experience w/DRC, which involved the tt going thru AD/DA. Mainly positive, w/some caveats. The q is, are those caveats critical?
In a nutshell the extreme bass boom in Keith's room has been properly tamed w/DRC, but some dryness/truncating of notes was apparent.
Everything in life is a compromise, esp at these exalted levels, and given a straight choice, the DRC'd sound was clearly superior. Still processing in my brain the upshot of all this.
Need to incorporate tubes in this system before I can make a firm conclusion.
I appreciate the efficacy of DRC. I can stomach DRC for subwoofer integration but I am not going to run a full-range, pure analog signal -- with not a single transistor in the signal path -- through DRC.
No they just dont add or take away anything, they are the closest amp to a 'straight wire with gain ' available, if you are used to distortion albeit pleasant they might take a little while to get used to.
Keith.
with all due respect, this is your opinion. please don't belittle mine. i've heard your amps - for example, they don't sound like live strings TO ME. and I run DarTZeel SS at home, not SET.
you are welcome to feel differently, but enough of the dogma dude.
I just have the upmost admiration for you, being able to determine the character of one specific component ,in an unfamiliar system in an unfamiliar room at a show!
Now if you had the Molas at home and compared them to your Dartzeel, then I feel your opinion would carry more weight.
Keith.
Hello gentlemen. Let's try better to be polite to one another. If an internet fight is what you want, do not do it on this forum. Please take it to private conversations or you may not like the final outcome should you choose the wrong path.
Tom
No they just dont add or take away anything, they are the closest amp to a 'straight wire with gain ' available, if you are used to distortion albeit pleasant they might take a little while to get used.
Keith.
I agree with KeithR. This sarcasm is totally unwarranted and inappropriate.
My apologies sorry Keith, Tom.
Keith.
It seems you continue to not understand why your absolutism attitude upsets people and is, IMHO, counterproductive to meaningful, respectful discussion. How many times do you need to be called to the principal's office?
Suffice to say I agree with Keith R. and Ron and understand why Keith R. may not wish to post in the future.
