Finished recently cleaning all of my vinyls! Fantastic, liberating feeling Had no idea that would be doable in any sort of a reasonable time. A BIG BIG THANK YOU Neil, Tima, and the rest of the enthusiasts here for paving the road.
That's great Jarek, congrats. Probably took you less time and you had more fun than using a single-slot desktop RCM.
Jarek,Absolutely! Plus vacuum will not clean as US cleans, let alone 2x US with different solutions. Adding the 2nd rinse UST was crucial for the speedup, thanks again guys!
Neil thanks! Your methods worked wonders. Honestly I've lost the count but surprisingly less than I thought. Some 400+ perhapsJarek,
Congrats, and just for the record (), how many records did you clean?
Best Regards,
Neil
Mine is invaluable (ORB), particularly for Amazon purchases which always seem to arrived dished. I always do a quick clean on the vacuum RCM before flattening to remove detritus as I don't want anything "baking" on to the record during flattening. No evidence that that happens, but easy to do a quick clean.PS Now I think I need a disc flattener
Won't they take those back at their expense? I won't accept a warped new record.
They will, but pretty much every record I get from them is dished so I prefer the path of least resistance with the flattener. I only buy from Amazon when I can't find the album from my friendly independent stores.Won't they take those back at their expense? I won't accept a warped new record.
And the flattener proves useful in the 2nd hand market where you cannot be sure of what you are getting. Sometimes albums arrive lightly warped or dished, which isn't necessarily a bad thing as it means it's likely unplayed for the same reason and sold on cheaply. After flattening you can get a mint copy of a desired pressing
In an ideal world they wouldn't be needed, but they are a very useful tool to have.
Absolutely. Sold goods, certainly under UK law, should be 'fit for purpose' and a warped record isn't fit for purpose and should be replaced by the seller without question.I'm not questioning the flattener, just thinking that ideally one should not have to accept new records that are warped.
Would be interested in thoughts: I have a non-forum friend who is claiming miracle results with "hot" fluids. He's using a mixture of water, a little IPA and a couple of drops of washing up liquid - heated to 80C which he is spraying onto the record and scrubbing in for 10 minutes, rinsing, and doing same again. He claims this is transforming previously uncleanable records (he uses ultrasonic) into silent records.
It seems intuitive that heat would assist cleaning, but I'm wondering if there is an optimal heat for our application? Personally, *I'm* concerned about spot melting at 80C, but he seems convinced it's safe. Would be interested in thoughts on this.
Finally, in terms of a detergent effect, would heated Liquinox be better than room temp? Or would something more acidic like distilled white vinegar or the other Alconix cleaner Neil has mentioned be more appropriate for the "hot wash" treatment?
Myself, I do a 60sec scrub with liquinox, then let it soak for another 60secs before vacuuming it off - then it's on to the ultrasonics, but am wondering about experimenting with a Citranox (which I'd need to import)/White Vinegar step for those stubborn records that remain crackly to see if I can get any further improvement.
Absolutely. I’m at the point where repeating a clean never improves the results, so there are no expectations of further improvements. Noisy records are written off as inherently noisy. However, a new process, in this case the “hot wash”, is at least worth investigating I feel. You never know…A question I asked myself long ago when I first started cleaning records is: when do you stop?
If I just clean it one more time will I finally remove that noise on side B?
Thanks, Neil. I've passed on the warning about IPA at the temp he is using.
His success with "hot washing" had me wondering about efficacy and optimal application of such a method as well as the potential for damage. My thought was that I'd buy a baby bottle warmer for this use - I've seen one that can give constant heat from 37-60C and would seem ideal for holding a bottle of warmed spray to use during cleaning.
