That would be simple. He would be too far away to hear me.Imagine you started running with Eliud Kipchoge, and didn't know exactly what he was, and then asked, where do we stop.
Mike only wants to improve the sound signal before the server gets it. Maybe you also know the better sound signal will give the better SQ. Every systems will have better SQ if we can improve the input sound signal. Your Taiko is also like that. You will see your Taiko will be improved with the tweaks even which is cheaper than Mike's tweak. I'm sure when Emile releases his switches and routers, you will not say these words.Mike, it is an oft mentioned comment but I guess it begs the question of how a relatively inexpensive tweak can improve the sound of a maxxed out killer server dac combo so easily that it is immediately discernible? And if it is so easily improved, where do you stop? I'm thinking Steve's philosphy of leave it alone is a masterful bit of self preservation to avoid going down the rabbit hole.
Well my words are certainly not thinly veiled criticism as I'm sure Mike knows. I guess what you're saying is akin to putting better petrol into your car which I concur with. My question posed was where it stops and I guess we all subconsciously know that answer which is it doesn't. Having inexpensive tweaks that improve SQ significantly is not much of a heartache anyway!Mike only wants to improve the sound signal before the server gets it. Maybe you also know the better sound signal will give the better SQ. Every systems will have better SQ if we can improve the input sound signal. Your Taiko is also like that. You will see your Taiko will be improved with the tweaks even which is cheaper than Mike's tweak. I'm sure when Emile releases his switches and routers, you will not say these words.
my plan was to improve my interconnects for the Wadax as i had been using a BNC with the MSB i had for the Playback Designs (from 2005), add the RevOpods due to the unique Wadax chassis shape, then find a good quality network switch plus LPS, and later get the Server power supply when it came out. then i happened to upgrade my Sablon Ethernet cable, and now the Qpoints. turns out the system seemed to react strongly to each step.Mike, it is an oft mentioned comment but I guess it begs the question of how a relatively inexpensive tweak can improve the sound of a maxxed out killer server dac combo so easily that it is immediately discernible? And if it is so easily improved, where do you stop?
Steve? leave it alone? avoid? really? after 6 figures + of racks + $50k + of CMS footers + 6 figures + of cables. even if you count my Tana platforms i'm not half invested in those things as he is. OTOH Steve is a guy who does want to just listen and not stress about going further once he is happy. but he has certainly done his share of optimizations. but most of it was a few years ago. and i'm not being critical of Steve, i respect his path.I'm thinking Steve's philosphy of leave it alone is a masterful bit of self preservation to avoid going down the rabbit hole.
god only knows.....Gosh Mike. Your Wadax must be skinless by now.
We are all enjoying your journey Mike.my plan was to improve my interconnects for the Wadax as i had been using a BNC with the MSB i had for the Playback Designs (from 2005), add the RevOpods due to the unique Wadax chassis shape, then find a good quality network switch plus LPS, and later get the Server power supply when it came out. then i happened to upgrade my Sablon Ethernet cable, and now the Qpoints. turns out the system seemed to react strongly to each step.
as far as inexpensive tweak mattering.......my biggest all time tweak for my system cost about $400......the cloth and thumb tacks i bought to treat my reflective wall surfaces 6 years ago. the Qpoints are a little serendipitous for sure. seems too easy and simple.
i guess we wait a month to see what happens when i remove them and listen.
once i pushed my chips into the middle of the table with the Wadax i have determined to follow the optimization path to the end......i've gone too far to stop now. the Qpoints were not planned. but after buying the Nordost Qsource linear power supply and learning about the Qpoints and their modest investment and that they can be inserted into my system simply just to try, it seemed silly not to.
Mike, is your wall covering just typical cloth wallpaper?as far as inexpensive tweak mattering.......my biggest all time tweak for my system cost about $400......the cloth and thumb tacks i bought to treat my reflective wall surfaces 6 years ago. the Qpoints are a little serendipitous for sure. seems too easy and
your room and the dedication to excellence was truly inspiring when I visited. It led me to doing some additional small tweaks to my acoustics and I am thrilled with the result. I think that bringing the noise level down without overdamping the room works wonders. Finding those small reflections that hinder the overall desired effect really brought me closer to the music.Mike, is your wall covering just typical cloth wallpaper?
today the two more "step ups" arrived. the first one (technically two pieces) has been playing for about 45 minutes now. it's the Nordost Qsource Linear Power Supply. with a 2 meter Qsource DC power cable plugged into the Nordost QNET switch. this is a very solid and heavy little bugger that i have sitting on my wall shelf behind my rack where my 2 EMIA SUT's sit. as it's not cheap, i was kinda hoping it would not move the needle. but of course it did.mostly more of everything good. more intense tonal density, greater ease and less stress, yet greater dynamic grip and contrasts. on my typical demo tracks i'm hearing more focus and sense of fingers on strings, voices more 'there' and 'expressive', words more intelligible on tracks i thought i knew exactly. now i know them more exactly. these are little things that all add up to a more real, less reproduced performance. it's doing what a good, well thought out, LPS should do.
and this is out of the box first impressions. not sure if this one breaks in or not. i guess i will find out.
bravo to Nordost for these (QNET switch + Qsource LPS + Qsource DC cable) network goodies. not spent the time to investigate the competition, but these have all delivered big time to my ears. and i have no plans to go down that 'compare' road, although i'm happy to A/B other units someone might send me.
i'll listen a little more and then try my last little 'step-up' bon-bon and see if there is any digital world's left to conquer.
For me it is the second one, a bit infused with the first oneIt stops when:
> Your budget runs out
and / or
> You come to personal realisation of the upgraditis affliction and actively make the decision to pull out of the madness
or
> You die
I guess I need a primer on what could potentially be involved. Thank you.
Peter, you never ask easy questions.Mike, for the sake of clarity, could you please make a list of every item in your digital front end from the wall outlet right up to the input on the back of your preamp? For a non digital guy like me, I want a better sense of what it takes to optimize a SOTA digital source. I had thought my vinyl source was complicated (with compressor, hoses, converter, power supply, two arms and various cartridges)and that digital was simply a player, DAC + transport, or DAC + streamer plus some cables. This is sounding much more involved than that. I am also trying to understand what each of these devices does for the playback, not sonically, but functionally. I guess I need a primer on what could potentially be involved. Thank you.
it's ordinary cloth you would find in a fabric store, purchased to blend aesthetically, cut and thumb tacked to the wall or ceiling. i took 9 months of effort to test every surface of my large room. so priceless amounts of sweat equity and testing, but pennies of purchases.Mike, is your wall covering just typical cloth wallpaper?
1---copper LAN in my house and barn, broadband cable into my home.
2---2 Synology mirroring 'file backup' NAS's, 30tb each, one in the house, one upstairs in the barn--same for MSB and Wadax. neither of these is in my signal path, as my files are resident on my Wadax server, as well as were resident on the Extreme server.
3---Netgear ethernet switch upstairs----with the MSB i also used fiber optic interface (with 2m Sablon Ethernet cable) which plugged downstairs into my Extreme server until the last few weeks when (Emile then suggested) i used copper CAT6 to go directly to both the Extreme and Wadax servers from the upstairs switch.
4---now with the Wadax'--Nordost QNET switch with Qsource power cable and Qsource LPS, Sablon 1.5m Ethernet Cable + brand ??? Ethernet cable also being demo'd, this now into the Wadax server.
5----Wadax Ref Server and Wadax Ref dac w/dual power supplies + the Akasa Optical interface; all this sitting on RevOpod footers + Taiko Daiza's. using Stage III Gorgon XLR interconnects from the dac to the dart pre.
6----Nordost Qpoint synergy devices + power cables plugged into the Nordost LPS under each Wadax chassis.
i do have 4 power cords plugged into my 'clean' Equi=tech power related to my digital; two for the power supplies of the dac, one for the server, and one for the Nordost LPS.
the music management software (Roon) resides inside the server, as do the streaming sources, in my case, Tidal and Quboz.
an i-pad or phone is typically used to navigate the music management software. analogous to a CD player remote.
objectively step by step.
broadband---->modem---->switch----->in-home network---->switch--->ethernet cable--->maybe another switch + linear power supply --->ethernet cable---server---> interface cable (USB/Optical/?)--->dac---->interconnects--->analog preamp.
some people use wifi to source their ethernet, it's not hard wired.....many steps above can be skipped. OTOH some people 'stack' network switches to increase the effect.
keep in mind most network stuff is cheap, cheap. even nice switches are modestly priced relative to our analog gear. it's only dacs and servers where 5 figure price tags come into play.
not sure all that helped with clarity.![]()
you are welcome.Thank you Mike. That post took some effort and I appreciate it. Reading this thread, I lost some of the sequence of items and specifics. This does make sense to me, and I understand that it can be reduced to the essentials, but I keep reading that as you add stuff, the sound continues to improve. This gives a good sense of what is involved if one's intention is to explore the edge of SOTA.
in the end i have come to appreciate my three tt's and vinyl choices.....but did decide to make some strategic upgrades as mentioned below a month ago.I know you mentioned somewhere that you are thinking about the vinyl chain again. I don't want to temp you to share these thoughts now or hear, but just want to write that I look forward to reading what you decide to do in that area. I suspect you will reduce the choices you now have and simplify just a bit. As with digital, there are some vinyl choices at the very top, IMO.
Clearly you have a passion for Audio.not sure all that helped with clarity.![]()
