No problem - give also the absolute value of signal.So we do in fact have absolute values for all of this, just that the "absolute" value for some things is relative to the signal.
--Ethan
--Ethan
...We can ague semantics but the point is to get across for general posters who consider measurements do not show us everything/measurements show us all, is the following;
1. Measurements involve a defined (includes scope) test procedure-process (you even state this on line 2)
2. The defined tests can also involve a tool to generate-trigger a specific response-behaviour-trait
3. Tests also involve a tool/probe (if you want a measuring instrument) to measure the parameter with quantative value (unit of measurement), in other words a source of data or even data acquisition.
I do see one fundamental mistake I made though, that was posting as if there is always a tool to generate-trigger a specific response, it is also quite possible for only passive analysing-measuring and depends upon the circumstances...
Because "you can't hear it on music that's near full scale when played at non-damaging volume levels" does not prove anything - we all listen to medium loudness and soft music at non-damaging volume levels.. But you can't hear it on music that's near full scale when played at non-damaging volume levels.
--Ethan
COULD YOU PLEASE NOMINATE THE TWO AMPLIFIERS YOU HAVE USED TO CARRY THIS EXPERIMENT?
Anyway, your private experience on dither does not agree with the experience of tens or hundreds of reaserchers and scientists who studied and published about the audibility of dither.
Unhappily you never give a straight answer to questions. I was interested in this thread because I have known for years your work about room treatment and could hope that your positions had a good fondations and we could have a fair talk about them . However you are not interested in measurements, but only in ambiguous statements and challenging everyone.Whatever amps were used in Richard Clark's tests described here will do fine:
Richard Clark, all amplifiers sound the same
--Ethan
OK, I must be a late bloomer but only now did I think to response to thisThere are four parameters that affect audio reproduction:
Frequency response
Distortion
Noise
Time-based errors
Of course, there are subsets, such as hum and buzz and LP crackles under noise.
Often when I list my "four parameters," someone will say there's more to audio fidelity than that. But every time I ask what else there might be, I never get an answer. I am ready to accept that there's more to audio fidelity than these four parameters, as soon as I see credible evidence.
--Ethan
...Putting that aside, let's look at another simple one: channel separation. Surely you don't want to bucket that in distortion...
Of course you should listen to your hardware to make the final decision. No one is saying you shouldn't. I think what people are saying is take the bias out of the decision. Setup a blind test with a friend making the swap and see which one you really prefer. No matter how much you trust your ears, they are subject to bias just like the rest of us humans. If you can't train or think your way around optical illusions you can't do the same for audio.For many years, there was only one measure of distortion that was recorded in amplifier portfolios, THD. With all the ringing, obscuring, and noise, fixed any notion in my mind measurements are to be trusted. I have always trusted my ears, and will continue to. When an audio component works to increase transparency, it is a keeper. I have been very lucky in my choosing components that do that. I never developed a belief in one genre of components over another. Lately I compared the solid state NOS 47 Labs sound to my tubed AN DAC. It wasn't a fare comparison, because my AN DAC is not off the shelf. The 47 Labs didn't measure up. It would be wrong to assume I am a lover of tube distortion. There are no other tubes in my system. I do believe a better solid state DAC will show up some day. It has to be NOS, and take advantage of all the most advanced components. Taking my AN DAC in that direction has paid huge dividends.
I hope listing these two paragraphs adjacent shows the illogic in some of these posts. If you ask me something and I answer, please do not accuse me 20 posts later of not having answered. It's futile - and even a bit depressing - when basic logic is ignored. A thread that could have ended successfully many posts back with all in agreement is still going on, and I'm still answering the same questions, and explaining the same logical fallacies, repeatedly.
--Ethan
I am sorry but I don't follow. According to Ethan's rule of four measurements, those amps would prove to have no value at all as lower-end amps can meet all the same metrics.Amirm, I do not think it is valid to start talking about channel sep or crosstalk, as the high end uses mono amps to compensate for just such things as you know.
Actually, LIM is considered a different class of distortion in DACs. Yes, its effect eventually manifests in clock jitter. But it is important to consider it independently.Also, if signal modulations within an ic chip cause the clock signal to jitter, thats timing errors in my book. Jitter is by definition a timing error. Jitter originates in the clock circuit itself and anywhere else it travels and is sped up or slowed down by what it goes through.
Well, it is my turn to say that is not a good argument. We may lose a lot of our high-frequency hearing but the critical 2 to 10 KHz range remains intact for people without hearing damage. Incredible amount of analysis can be done by the ear in that region.If you go to an audiologist and have this proper type of test done (most dont have a sound chamber), then measurements will reveal just how lousy and common and everday and cheap junk your ears are compared to all the sounds that are out there that humans can hear. While this does not mean that you can not discern sound signatures, it pretty much humbles even those of us with the biggest egos. DBT tests do this as well.
So what is that if we measured it, we wouldn't be able to make sense out of it. What is the point of the measurement if it is not to teach us what is wrong with the equipment?I would say that all of your examples save one are forms of distortion from different causes which you clearly describe. So what if the category is large.
LIM exists outside of a single IC if that is what you are describing.Many eschew integrated circuits and use discrete electronics with point-to-point wiring to get around many of the problems to which you allude.
I knew you would read Orb's question to me and address it. Thanks.
Ah k I understand now and thanks for clarifying.Orb, Thanks for the reply. There is a lot of symantic confusion on this collossal thread. My point is that blind measurements will often give you wrong answers. Measurement and testing are interactive, iterative processes that strive for an understanding. They are mini science experiments.
I liked post 629, nothing to comment about in it apart from you made a lot of valid points including that if using a parameter too generalised (such as seen with distortion that you highlighted very well in 629) it is very difficult to debate it when used to support a case/hypothesis/etc unless digging deeper and considering both test scope and measurement resolution.Amirm, I do not think it is valid to start talking about channel sep or crosstalk, as the high end uses mono amps to compensate for just such things as you know. I think that is just not a very strong arguement personally. But of course we await Ethans response anyway.
I am feeling left out because no one jumped on my recent post! #629
Here is another one for why some audiophiles fear measurements.
As a lad of 17, I enlisted in the US Air Force. Part of the extensive physical was a hearing test at the joint military induction center. Here is how it went:
They put you in a thing that looks like one of those undersea subs. Inside you pop on some stereo headphones and in each hand, corresponding to each ear, you grab hold of a push button type device. Your job, is when you first hear a tone in whichever ear, you press the button quickly, and each time you hear a tone you do this. The tones were fairly low and went up to fairly high frequences and at appropriate levels (and yes, who knows how accurate the headphones were...but good enough to figure out who could qualify to be a sonar operator protecting hundreds of millions of dollars of ship, etc) They start with the tones below audibility so you can not second guess, and also because apparently if you start with audible tones, as they go down lower, your brain starts "hearing tones" and you second guess yourself. Damn measurements will show you just what your ears are made of!
Want to clear audiophiles out of a room, tell them they all have to take a hearing test and it will be published!
Talk about FR errors, yikes!
Tom
Heck, why does he have timing error as a category if having stuff lumped into one bucket is just fine? Why not through that out also and express it as distortion? You consider that progress if we did that?.
To be fair, what he lists are some of the basics that we measure.
But the science of understanding high-end gear performance is more complex if the idea is to learn and understand.
you are being unfair in the way you lump just about everything in distortion.
There are lots of distortion types and if you listed them all, your list would get a lot longer.
The next one would be transient crosstalk. Imagine a 2x200 watt amp being driven by a 100 watt power supply. A sustained peak at 100 watts, will surely cause transient crosstalk in to the other channel by robbing it from its power linked to precisely what is being played in the other channel.
Compressed audio systems and FM receivers do even more whacky stuff by adaptively changing the stereo separation based on signal level and amount bandwidth available respectively.
Why do some audiophiles fear measurements? Measurements can prove that your ears are wrong. Your ears can not prove that measurements are wrong.
One of the main reason high-end amps exist is because that extra class of distortion, namely, crosstalk which is absent from his list.
