Common man. Think Captain Kurk. Exploration. Be somewhere we haven't been before. This is whatwe in for Ked. Beside it is not like I lost the Cessaro sound. I am not selling. The Eurodyn is going to be just great.You are also a fool to move this out when it has started sounding so good with the last few videos from Arpegionne, this, the tape, etc.
I came to a similar realization when I started hearing how good SET topology COULD sound and then wondered if there was any research behind what I was hearing. I started looking at psychoacoustic research and what was being learned about distortion and it's perception. First was the realization that there is essentially NO correlation between THD and IMD and sound quality. This was explored by Geddes and Lee in a couple of sound perception papers. They also came up with a rather complex metric for making predictions about what was most acceptable to listeners. They didn't conclude that SET was the best extant technology but the forms of distortion that were least offensive are best served by that technology. Cheever came up with a similar conclusion and also proposed a metric that was based on our understanding of human hearing, self-harmonics and masking, that is dependent on SPL as well as distortion content (the SPL determines which harmonics are masked and which patterns are "tolerated"). Again, SET makes the patterns and follows the psychoacoustic "rules" better than other topologies if the right power/distortion/SPL behavior is followed (I.e. use a sensitive speaker for the given SPL so the amp is not too stressed and therefore making the wrong distortion components).
Lamm must have come up with something similar and thus the ML2 was born. I think the hybrids and the PP tube amp were considered reasonable compromises and still sounded better than most other amps into the kind of speakers for which they were designed. Then the ML3. So, the two marquee amps are SET and for good reason.
PeterA should like this album very much I think.
Download Nordvpn or turn on your Norton Ani virus VPN, which will make the IP address seem as if from another country.
Thanks for the suggestion. I'd probably choose Express VPN which supports split tunneling, but I have enough software to support as it is. Maybe you could say what the videos are.
They are the same track as Tango's played on a Neumann DST and EMT TSD 15 (modded by vdh), both played back on the same Altec A7. I had posted these on the male vocals thread earlier.
Express is fine too, any VPN
Could you just say what they are?
Did you look up Tang's video? Schubert Schwanengesang. ALP 1827
No. My suggestion is not to make postees go searching when you have the information right in front of you.
Schubert Schwanengesang. ALP 1827 - that is helpful.
Schubert revisits the themes of death and the maiden several times during his brief life and this is the final reference contained within his Swan Song.Some time I wonder how I got to where I am in audio and musical taste. I have to admit if it weren't for Bonzo I would not be enjoying classical music and my system as a whole as I am now. Classical music is what I listen to most on vinyls. I even listen to Lieder now...unbelievable because I don't understand a word he sings . I have to read the translation insert that comes with the album to get a clue. Do you guys know what he is singing in Strandchen? I read the translation. If I and Opa Lagonda were to interpret the meaning, we would say the guy is singing I am horny.
Here is a really good lieder album with excellent sound. Schubert Lieder Recital No.4, Dietrich Fischer-Dieskau. HMV ALP1827 in mono. I bought from Discog and was at approachable price. I think this album can sound good in any system but to get an emotional involvement to really 'watch' how he sings you will need something special in your system. (Separate men from boys as MikeL liketo say) For me the Master Sig 5R does it. The Opus and the Gran Cru don't do it. ( No supremacy. Many lps I like Gran Cru and Opus more than 5R. This is why need a few carts in the system) I didn't play with my MS Mono Replay cart because it wasn't on any arm. Videos cannot show. It has to be in room listening. Actually, I think I could do better if I use the Neumann DST. I don't think I have heard a better more realistic vocal tone with such compelling emotion from other carts. I could say this because when I auditioned the DST that system also had a vdh master sig to compared. If I go audition systems I would take this album with me because I know what I would look for with that last bit when listening. PeterA should like this album very much I think.
Really great sound Tang! Do I understand correctly that you will swap these for a Eurodyn system? Just needing a different flavor of perfection??Some time I wonder how I got to where I am in audio and musical taste. I have to admit if it weren't for Bonzo I would not be enjoying classical music and my system as a whole as I am now. Classical music is what I listen to most on vinyls. I even listen to Lieder now...unbelievable because I don't understand a word he sings . I have to read the translation insert that comes with the album to get a clue. Do you guys know what he is singing in Strandchen? I read the translation. If I and Opa Lagonda were to interpret the meaning, we would say the guy is singing I am horny.
Thank you Brad. Yes, I will put these Cessaro in a storage and the less high extension, better mid band, better bass, even more physical Eurodyn system will go into the room instead. The presentation will be different for sure. But it will have the essence of believability at least no less than what I have with Cessaro. So different flavor? Yes I am in for that. Ddk said I will love it. He knows my type of sound. I trust he will make sure I have the sound no less good than his.Really great sound Tang! Do I understand correctly that you will swap these for a Eurodyn system? Just needing a different flavor of perfection??
1.8m X 1.8m baffle.@Tang will you have the large baffle or just the naked eurodyn?
