Yes, I understood that. It was also clear in yr other post on R's choices.
R for Ron or Ron Resnick?
I talked about sibilance in the Master Sig thread and look what ddk sent me. Three pairs of RCA's and a roll of speaker cables from Amazon. LOL.
This is his way with me. He never persuaded me..but leave the option to me to try myself.
I am very very happy with my Kuro. I am also not Ron Resnick on sibilance. I will try these cheap cables only if I change to new amps and preamps and the sibilance gets too hot.
My journey continues.
Tang![]()
Ok I clarified why I am on about the inconsistency in the other thread
What other thread are you guy's discussing? I missed this one about Ron's arm/cartridge musings.
So Peter, are you going to jack your Vibraplanes in anytime soon? I mean, like pricey cables, a tweak is a tweak. And Vibraplane is not necessary for yr gear, SME, Pass etc don't supply yr gear w it.
Do yourself a favor and at least try the Radio Shack ICs. It won't take long, and you may be shocked or pleasantly surprised.
Tango, you want to dance? David suggested to me the exact same cables and wires. I'm not a client, so he didn't send them to me for free, hehehe. I really like the 1M Radio Shack IC. The longer ones to my amps have a grounding loop or something which I may try to sort out., but I can't listen to them as is. I have not tried the speaker cable yet. I love the idea of saving money any way I can in this hobby.
(...) The longer ones to my amps have a grounding loop or something which I may try to sort out., but I can't listen to them as is.(...)
Isn't your system fully balanced?
Yes, system is balanced. I wanted to try out some cheap Radio Shack cables which are single ended. This is a long run.
Why discuss this on Tang's thread?
He sent me the same, including his alignment tool, power cords ,a extra headshell and a leather mat. Still stuck in customs, they are probably wonderingI talked about sibilance in the Master Sig thread and look what ddk sent me. Three pairs of RCA's and a roll of speaker cables from Amazon. LOL.
Tang![]()
