Ron, I did run a handful of Zu Event cables in my system 5 or 6 years ago.
Good as they were, they didn't beat my Audience Au24 cables, and pale in comparison to my current Sablon loom.
After spending time with Sean Casey I am considering literally commissioning Sean to make a custom cable at exactly the length (approximately 17 meters which will be verified initially with Mogami) I need based on the output impedance of the VTL 7.5 Series III preamp and the input impedances of the Gryphon bass tower and of the VTL Siegfried Series II.
Isn’t custom impedance matching based on component input and output impedances and on length of interconnect what Transparent Audio claims to do?
Go for it Ron.
Sean's loom is impressive, excellent for the price.
He's a great guy to deal with.
Do consider my current magic man, Mark of Sablon Audio, for additional cables.
Right now I am focused only on the very long interconnect issue. I don’t want David to come in and Swoosh! the preamp out of the equipment room and into the listening room to break up the interconnect length, and Swoosh! away the long interconnect and replace it with two shorter lengths of Ching Chengs!
He does that, doesn't he LOL
At Christian SWOOSH, Entreq in the bin
At Tang SWOOSH, subs switched off
Good thing he never went over to SteveW and Audiocrack, and SWOOSH SWOOSH ditched their CS footers and Troy boxes LOL
Remember that for long (say 20 to 50 feet) RCA analog interconnects, the most important parameter is low end-to-end resistance of the shield. There can be 20dB differences in Common Impedance Coupling noise between common coax cable types.
I'll be honest- all this tone and density out of cables confuses the heck out of me. I've heard similar from Kubala Sosna which seems to push mids out with loads of presence which some enjoy, but I find the opposite of what cable is supposed to do.
I would prefer single-ended, sonically, myself. But at 17m I think balanced is highly advisable.
Actually, a very good experiment would be to get Mogami balanced and Mogami single-ended and assemble a panel of WBF members to compare the wires. (I will provide snacks and alcohol.)
