Tim, can you explain how the pump comes into play. Is constantly helping clean the water during the wash cycle or does it get used after the wash cycle is complete to filter the water?
Here's my KL Audio RCM filtering system. It's easy and it's cheap. Info sources for information on this are diyAudio, TIMA's DIY Ultrasonic RCM here and his The Vinyl Press update.
You need a pump, a filter and housing, a few feet of 3/8" clear hard plastic tubing, 4 x 3/8" hose clamps and 2 x 3/8" hose barb fittings. I used an Attwood 12VDC water pump mounted on a board with an AC/DC converter, and a 2 3/4"D Flow-Max .35 micron filter in a Pentek 158116 10" tall filter housing. Materials will cost less than $125. (Please double check sizing of hose, clamps, and hose barbs!).
Hook-up is easy. First connect the KLA waste water tubing at the bottom of the unit to the input of your pump. The output tubing of the pump is connected to the input of the filter housing. The output of the filter housing tubing of appropriate length is plugged and hung above the top of the tank somewhere so it doesn't leak out. You'll need to add water to the set-up to fill the tubing and filter canister and maintain the level in the KL Audio machine where it's supposed to be in the resevoir window. It's a little bit of trial and error.
You do NOT run the filtering system when cleaning records! Do it separately. When you want to filter the water in the KL Audio unit's tank, unplug the tubing line that's exiting the filter canister and stick it into the the KL Audio tank filler hole next to the record slot in the top of the unit. Open the resevoir drain valve at the bottom of the KLA unit, and turn on the pump. You'll see the water flow out of the KLA tank, through the pump and filter canister and back up into the KLA unit at the top of the unit. I let it run for 5 minutes or so.
Decide how you want to set everything up near the KL Audio RCM before you order the tubing so you'll know how much you need. I have the KL Audio on a table and the pump and filter on the floor below but I'm guessing any location will work.
Barry is helping me as I figure out how this works and what parts I need.
My understanding is:
The KLAudio drain is 3/8". This connects to intake of the pump which is either 1/4" or 1/2".
Assuming I use 3/8" tubing I guess I need to get the right fitting to go from 3/8" to either 1/2" or 1/4".
The pump discharge is 1/4". This tube goes into the filter canister which is 1/4". The tubing here is 1/4"
The outflow from the filter is also 1/4". This tubing goes into the KLAudio water input opening. The tubing here is 1/4"
Any comments would be appreciated.
It's certainly possible to find hose barbs that fit a certain sized opening and reduce or enlarge that to a different size. You'll wnat to be aware if the product you're looking at is male or female, which will be dictated by the intake/output opening you're fitting to. I would expect KLA specifies or can give you a spec for the drain.
For example: if the drain has an 1/2" female fitting, then something like this might work: https://www.amazon.com/dp/B075VGSFM...&pd_rd_r=65a7683b-29da-11e9-9ba3-db60abb02adc
There's a certain language of pipe fittings. FPT = female pipe thread, MPT= male pipe thread. NPT = national pipe thread; this just refers to compliance with American National Standard Pipe Thread standards. It's funny all the stuff you learn doing audio. There's a boatload of plumping and pipe-fitting outlets online and thousands of different types of fittings made from differemnt materials. Brass, stainless steel or nylon are usually good choices for what you're doing.
Take a look at the drop down selector at this page and you can get an idea of what is possible. https://www.amazon.com/Anderson-Met...id=1549436669&sr=8-25&keywords=NPT+hose+barbs
Remember it never hurts to use a bit of teflon plumbers tape when making connections.
Thanks Barry! As far as the parts and setup goes, sounds like you've got it covered.
We differ on use. I'm curious why you do not run the filtering system while cleaning records? Is it because there is not enough room for the filter's return hose in the KLA 'slot' with a record in place?
I have to figure out what is the best way to empty all the water than remains in the filter system once I close the drain plug because when I do that the water stops flowing.
Tim,
Thanks for the comments.
My KLAudio has the internal tank. Your comment about filling the filter canister is what I was thinking about. If I don't do that then when the system starts up it first fills the canister. Yesterday when I was all done with the cleaning, the KLAudio tank was far from filled since a good amount of that water ended up in the system, including the canister.
Now that I have a filtration system I have to think about whether it is worth it to add the USC and rotisserie and just have a complete cleaner. I like the KLAudio and I like the fact that it dries. However, I have started to hand scrub records with l'art du son and a brush first and then run it through the KLAudio. I find this method clears some of the crud that the KLAudio does not. I am not sure that the DIY cleaner is a good replacement for the hand scrubbing.
Are there any DIY setups that scrub too?
I wrote the folks at KLAudio and they do not recommend using any surfactants due to the potential harm to some of the parts inside.
So, I am at a cross roads since the cost of the Elmasonic is close to $3k.
Edit: I found the P120H for $2,549 all in. That is probably the lowest price I will find.
I can deal with the Kuzma costing $1k.
I have to see what alternatives I have for the USC if I want to try to reduce the total cost.
That is a really great price for an Elma P120H !
The Kuzma RD MSRP is $1400. Do places discount this at all?
