Zero Distortion: Tango Time
Tango
4,938
6,269
950
Bangkok
tima
5,853
6,930
1,400
the Upper Midwest
Do you vacuum after sonic clean? That's important.
Vacuuming is relevant only if your RCM is horizontal - in fact that is what horizontal RCMs are: vacuum cleaners. Ultrasonic RCMs are vertical. You don't need two machines. Probably not a topic for this thread, but, cats.
Folsom
6,032
1,503
550
Eastern WA
I’m sorry that just isn’t true. A friend of mine was very early adopter for sonic cleaning and found discs are much cleaner, much less noise if you vacuum them with some distilled water after sonic clean.
The sonic clean brakes up debris, but they often float about and stay on the disc, even if you have a pump filter for the water solution.
There are many different vacuum RCM’s that can be used. I have a manual one Squeaky Clean. It’s nice in that if I slowly rotate it after a quicker rotation then it’ll become dry from air flow. I use a solution to help get dirt/debris.
tima
5,853
6,930
1,400
the Upper Midwest
I mean no disrespect, you're working with too little information.
You (or your friend) are talking about a horizontal RCM - not sure what is meant by "sonic cleaning." "Sonic cleaning" means cleaning with sound; I believe you mean simply "cleaning.". There are no horizontal ultrasonic RCMS on the market and none that are custom; to my knowledge in principle it is not possible to make one.
Horizontal systems such as Loricraft or Monks coupled with enzyme based cleaners can do a very good job. It's one side at a time, a lengthy process and very messy. Their vacuums do work. Some people who have them continue to use them. (I still have my Loricraft, though it's boxed.) However new RCM purchases are largely surplanted by USC machines. Ultrasonic cleaning is at least as good (and better based on my experience) without the mess and time. Some 'audiophile' desktop ultrasonics are okay, one record at a time - they are about convenience - but it is difficult to keep the machine itself clean.
I'll refer you to one of my recent articles, here.
If you're commited to a horizontal RCM check my article from 2011, here. Much more there than just about a product.
Might I suggest any follow go here so we not take up further pixels in Bongo's thread.
rockitman
7,097
414
1,210
Northern NY
Vacuum for drying == Static == Dust collecting LP's. It is really as simple as that. Once I clean with my KL Audio, I don't heave to clean the record again for years. Any dust blows right off the record...no static cling.
Reactions: jeff1225
Folsom
6,032
1,503
550
Eastern WA
No. What is this nonsense???
When I say sonic cleaning, I MEAN SONIC CLEANING, WITH A SONIC CLEANER THAT PRODUCES HIGH FREQUENCY WAVES IN LIQUID. THEY ALL DO THIS.
And you’re wrong, I’ve seen a horizontal sonic cleaner, made by some audio company, on a blog somewhere.
Anyways when you are done SONIC CLEANING, for best results a vacuum is a must.
But unlike what Rocket thinks, you don’t put a dry record on a vacuum RCM and dry vac. You use a wet solution. In mine I use a few different things for both cleaners. If you have a sonic cleaner that allows more than water, you’ll also get cleaner albums. Water alone isn’t as good of an anti-static measure as a percent of hepistat cleaner that also neutralizes biologicals.
I put vinyl that is clean, but not from me cleaning it, through my RCM vacuum just to kill the static. I have more static than most in my room. If vacuuming increased static I would have blown my brains out by now. But it reduces it so I can go on without going crazy.
IF YOU WANT THE CLEANEST RECORDS POSSIBLE, A VACUUM AFTER SONIC CLEANING IS A MUST. (And obviously you use a solution that helps extra the remaining debris, dry vacuuming wouldn’t do much)
My friend and others have been doing this well before any commercial sonic cleaners were available. They have literally been at the forefront the entire time, and get superior results since their setups aren’t constrained to purely water, and they can remove the remaining stuff that floats in water (even with a surfactant in it).
bonzo75
22,640
13,668
2,710
London
Guys there is an ultra sonic cleaner discussion thread this can be continued on
Reactions: KeithR
jeff1225
3,013
3,265
1,410
51
The KL is the single best investment I've made as a record collector. I seldom use my stylus cleaner and gave away my static gun.
Folsom
6,032
1,503
550
Eastern WA
Talk to tima, I had a simply suggestion for Tang, which has blown up because tima doesn't believe I mean what I type.
Tango
4,938
6,269
950
Bangkok
Today I show a very special vinyl. The General sent me this Echos De Rompon, R. Schumann. First time I listened to it, it shocked me caught me off guard. I didn't know there was a guy singing in this record. I thought it was pure piano. I actually twitched..hahaha. The sound is so damn realistic. Piano is on the left and this guy sings from the right right behind the speaker. Probably cannot locate that on youtube. I bought 5 different Echos. Very expensive. They are among my references of piano from vinyl. Will post more on them later.
Btw Mr. Kedar you can not use the £550 ERC Magda Tagliaferro as piano sound reference. :p And the General won't let you hear this one at his. :D:D:D
Tang
Reactions: zerostargeneral
bonzo75
22,640
13,668
2,710
London
The General thinks the Magda is one of the best piano recordings, as is this one. I haven't heard the Echos at his, heard the Magda twice among many other piano recordings. And yes, he has 10000 more that I haven't heard.
I use more than one piano reference. There are different types of sound.
tima
5,853
6,930
1,400
the Upper Midwest
Tang
It is helpful if you post a record's catalog number. Thank you.
bonzo75
22,640
13,668
2,710
London
Lol you won't find this one in good condition
bonzo75
22,640
13,668
2,710
London
Live piano sound, Schiff on Bosendorfer
tima
5,853
6,930
1,400
the Upper Midwest
Sure, but I might be able to find enough information to know who's singing. It's helpful to post the catalog nbr. when you highlight a record.
edit:
vocal Henk van den Brink
piano: Jeanne Bovet
Tunicaphon AG - 30-773
Switzerland 1982
edit2:
And fwiw, there is more than one record by Ms Bovet with the title 'Echos De Rompon'
Bach / Tunicaphon AG - LP 25-192
Bach / Scarlotti Tunicaphon AG - LP 30-538
stehno
1,593
460
405
Salem, OR
Tang
Hi, Tango. A few others had suggested that I check out some of your in-room recordings and I must say some of your in-room recordings are rather impressive and you're to be commended on assembling a pretty musical playback system. Far more musical than many I've heard here and elsewhere.
But I'm curious about this Echo piece. You said above that this is "so damn realistic" and I'm curious why you say that? I've heard some of your other in-room recordings and I thought some of them were significantly more realistic than this piece.
Tango
4,938
6,269
950
Bangkok
Will do Tima. I am out picking up my kid for piano lesson now.
