No. What you mean. How?Do you vacuum after sonic clean? That's important.
I’m sorry that just isn’t true. A friend of mine was very early adopter for sonic cleaning and found discs are much cleaner, much less noise if you vacuum them with some distilled water after sonic clean.
The sonic clean brakes up debris, but they often float about and stay on the disc, even if you have a pump filter for the water solution.
There are many different vacuum RCM’s that can be used. I have a manual one Squeaky Clean. It’s nice in that if I slowly rotate it after a quicker rotation then it’ll become dry from air flow. I use a solution to help get dirt/debris.
I mean no disrespect, you're working with too little information.
You (or your friend) are talking about a horizontal RCM - not sure what is meant by "sonic cleaning." "Sonic cleaning" means cleaning with sound; I believe you mean simply "cleaning.". There are no horizontal ultrasonic RCMS on the market and none that are custom; to my knowledge in principle it is not possible to make one.
Horizontal systems such as Loricraft or Monks coupled with enzyme based cleaners can do a very good job. It's one side at a time, a lengthy process and very messy. Their vacuums do work. Some people who have them continue to use them. (I still have my Loricraft, though it's boxed.) However new RCM purchases are largely surplanted by USC machines. Ultrasonic cleaning is at least as good (and better based on my experience) without the mess and time. Some 'audiophile' desktop ultrasonics are okay, one record at a time - they are about convenience - but it is difficult to keep the machine itself clean.
I'll refer you to one of my recent articles, here.
If you're commited to a horizontal RCM check my article from 2011, here. Much more there than just about a product.
Might I suggest any follow go here so we not take up further pixels in Bongo's thread.
Vacuum for drying == Static == Dust collecting LP's. It is really as simple as that. Once I clean with my KL Audio, I don't heave to clean the record again for years. Any dust blows right off the record...no static cling.
Guys there is an ultra sonic cleaner discussion thread this can be continued on
Probably not a topic for this thread, but, cats.
Today I show a very special vinyl. The General sent me this Echos De Rompon, R. Schumann. First time I listened to it, it shocked me caught me off guard. I didn't know there was a guy singing in this record. I thought it was pure piano. I actually twitched..hahaha. The sound is so damn realistic. Piano is on the left and this guy sings from the right right behind the speaker. Probably cannot locate that on youtube. I bought 5 different Echos. Very expensive. They are among my references of piano from vinyl. Will post more on them later.
Btw Mr. Kedar you can not use the £550 ERC Magda Tagliaferro as piano sound reference.And the General won't let you hear this one at his.
Tang
It is helpful if you post a record's catalog number. Thank you.
Lol you won't find this one in good condition
Tang
Will do Tima. I am out picking up my kid for piano lesson now.Sure, but I might be able to find enough information to know who's singing. It's helpful to post the catalog nbr. when you highlight a record.
