In case this happens you should send the whole set to Lamm. Elena will find the guilty tube and send you back a matched tube with the three good ones, charging just one tube. Usually the problem is not 6h30 going bad, it is mainly becoming mismatched when they age.
Although my experience with the ML3/LL1 is not long I have a decade experience with the 6H30 - the Audio Research's have a lot of them, at some time my system had 20 x 6h30's ! I built a dedicated tester for these tubes and found that a few had problems of infant mortality during the first 200 hours and that noise and several parameters only stabilized after 100 hours burn-in. Audio Research gear (and the VTL Siegfrieds, BTW) have hour meters I have 6h30 tubes with more than 6000 hours on them that still test perfectly.
Hour meters should be mandatory in tube equipment. It is a shame that most of the audio industry is still the age of the ignorance and voodoo on this subject. Surely IMHO, IMMV!
