Gary, should we couple or de-couple? When should we use spikes or vascoelsatic. Does it matter or am I just confused?
For my mini speaker I used a Target stand withspikes on carpeted wood floor. Additionally there were additional spikes under the speaker with velcro tabs.
PS I also placed 20lb weights to make sure the speaker was heavy enough to make the spikes effective.
What about heavy speakers (~200 lbs) on a hardwood floor on 3/4"plywood over concrete slab (i.e., two different woods, two layers of glue and one of thin felt padding all over concrete, no suspension)?
If I may be so bold to throw in another point of view:
If I were Greg, I would try four small beads of Blu-Tack under his mini speaker at the extreme point of each corner, replacing the upward spikes, and add any extra weight he possibly can to the stand, so long as it was solidly bonded to the stand. What I did was just add passive, paper based weight on top of speakers, made a big difference in my case.
If I were rrbert I would simply try those same four beads, but bigger, under the corners, "gluing" the speaker directly to the hardwood.
Frank
You don't specifically say so, but it seems that with heavy speakers and the right ball/cup, you could have an almost perfect support?
Blu-tac, as I mentioned, is a good coupler at audio frequencies. Hence, Frank's suggestions will be good for Greg and rrbert situations. I would add that blu-tac must not be used just pulled or cut off the pack. You have to pull and knead it until it warms up and softens and becomes more sticky. This deforms the molecules to their viscous state. Then, while they are still warm and soft, put the four beads as little balls on the corners of the loudspeaker/stand interface, and press down until they couple.
The molecules will pull together as they relax and couple the speaker to the stand even better. Coupling at the molecular level!!
Yes, I think so. Until I designed all my speakers with their own suspension systems, I had great results with the FIM ball/cup - but I switched out the ball they supplied with a tungsten carbide ball. With equipment, I also used ceramic and ruby balls.
I'm not familiar with the FIM ball/cup; is there a link which can provide more info? Do Symposium Rollerblock II's work?
...My objective for this thread was not to provide a comprehensive answer but just to open discussion.
We all know about the benefits of decoupling the motor from the plinth of a turntable,
and also the effectiveness of a well-damped, ultra-low-resonnance plinth, as well platter.
And we all know that some of the best & most expensive turntables use acrylic in one of two (or even both) parts of the above.
...Clear Audio for example, from Germany.
* Welcome to the VPI Classic 3 turntable ($6,000) whose motor is integrated into its plinth.
- The AC synchronus motor interfaces with an 18-lb aluminum platter damped with a stainless-steel disc bonded to its underside.
- The plinth is made of a plate of machined aluminum (1/2"-thick)) bonded to a steel subplate (1/8"-thick) which is itself bonded to MDF (2"-thick).
- The platter material is damped aluminum, which can be more precisely machined than acrylic, and is more easily damped, more resistant to changes in temperature and humidity, and more dense.
And according to Harry Weisfeld (VPI founder and designer), and Michael Fremer (turntable guru, audiophile, and reviewer); it sounds better than acrylic.
-> Full review in the October's issue (2011) of Stereophile.
