dminches
3,482
2,859
1,410
Got the bracket. Installation took 5 minutes. The fit is very different. Connected and listening. Let’s see how things go (even before any firmware update).
Rhapsody
3,470
6,560
2,535
Brooklyn NY
Rhapsody.Audio
I did the same. No luck. Extreme is not connected on line via the new card/new bracket. Back to the old card for now.
dminches
3,482
2,859
1,410
That is a bummer. Sounds like your card’s issues go beyond the bracket.
Rhapsody
3,470
6,560
2,535
Brooklyn NY
Rhapsody.Audio
Yup. I could not get my new card to work sans bracket. You were able to use the new card without bracket. I could never get it to work without the bracket, SO I probably have the issue that they are working on right now. I am just so relieved that I can put the old card back in with the switch and it comes right up, no issue.
dminches
3,482
2,859
1,410
I assume you reconnected the power? I am asking only because when I first tried the card sans bracket I forgot to.
Rhapsody
3,470
6,560
2,535
Brooklyn NY
Rhapsody.Audio
Yep, unfortunately I did connect the power. But thx. Definitely could have been that!
Reactions: kennyb123
cat6man
913
1,050
1,185
west of NYC, east of SF
Exactly the same here. Even without the bracket mine was erratic. The new bracket makes the fit feel secure but after coming home from playing tennis, the connection was gone :(
On the other hand, I left the new bracket and card in and will move the Ethernet to a mobo nic for now. I do not want to have to pull the extreme out of the rack again!
I'm happy to wait that way for the fw fix.
Rhapsody
3,470
6,560
2,535
Brooklyn NY
Rhapsody.Audio
Exactly the same here. Even without the bracket mine was erratic. New bracket makes the fit feel secure but after coming home from playing tennis, the connection was gone :(
I do not even get an initial connection.
dminches
3,482
2,859
1,410
So bizarre. I assume that Emile and team have an explanation for this.
I assume we are all using the card with the switch so the basic conditions are the same. I also assume we all put the card in slot 2 where the old SPF card was.
cat6man
913
1,050
1,185
Where can you see if the files are WAV or FLAC files. I've never paid any attention other than if they were 44.1 or DSD files.
I believe all streaming is losslessly compressed.
Rhapsody
3,470
6,560
2,535
Brooklyn NY
Rhapsody.Audio
I am talking about files that I have in 44.1 on my Extreme. Not streaming. How can you tell if they are WAV or FLAC?
Rhapsody
3,470
6,560
2,535
Brooklyn NY
Rhapsody.Audio
It is bizarre:) Some work, like yours. Others have the connection and then it drops. I have no connection regardless of bracket or no bracket. But with mine as soon as I put in the old card, it connects right away. Go figure:)
dminches
3,482
2,859
1,410
You would have to look at your drive in explorer. I don’t think XDMS gives you that information. Roon probably does if you tap on the star.
Reactions: Rhapsody
oldmustang
1,072
3,177
1,445
The file extensions on the track files will tell you: track1.wav, track1.flac, track1.dsf etc
Steve Z
Rhapsody
3,470
6,560
2,535
Brooklyn NY
Rhapsody.Audio
Roon shows it but I don't see it but I don't see it in XDMS. In XDMS it just shows 44.1 etc. No big deal other than to know if I heard a difference thinking WAV could sound better but ???
Rhapsody
3,470
6,560
2,535
Brooklyn NY
Rhapsody.Audio
Yes, I see it in finder on a Mac and then in Roon. Too much trouble:)
dminches
3,482
2,859
1,410
@Taiko Audio So without the bracket my Extreme was up and running for 5-6 days without any issue. Today, after installing the card with the new bracket I lost a connection between 90 and 120 minutes.
Bizarre.
Rhapsody
3,470
6,560
2,535
Brooklyn NY
Rhapsody.Audio
Bizarre.
It might sound like we are complaining. Not the case. Just giving feedback so @Taiko understands what is going on out here, which they probably do, but we're making sure:)
Reactions: Christiaan Punter
Rhapsody
3,470
6,560
2,535
Brooklyn NY
Rhapsody.Audio
Steve W. Are you still up and running?
dminches
3,482
2,859
1,410
Absolutely. Shit happens. Just trying to provide data points.
