I did the same. No luck. Extreme is not connected on line via the new card/new bracket. Back to the old card for now.Got the bracket. Installation took 5 minutes. The fit is very different. Connected and listening. Let’s see how things go (even before any firmware update).
Yup. I could not get my new card to work sans bracket. You were able to use the new card without bracket. I could never get it to work without the bracket, SO I probably have the issue that they are working on right now. I am just so relieved that I can put the old card back in with the switch and it comes right up, no issue.That is a bummer. Sounds like your card’s issues go beyond the bracket.
Yep, unfortunately I did connect the power. But thx. Definitely could have been that!I assume you reconnected the power? I am asking only because when I first tried the card sans bracket I forgot to.
I do not even get an initial connection.Exactly the same here. Even without the bracket mine was erratic. New bracket makes the fit feel secure but after coming home from playing tennis, the connection was gone![]()
Where can you see if the files are WAV or FLAC files. I've never paid any attention other than if they were 44.1 or DSD files.
I am talking about files that I have in 44.1 on my Extreme. Not streaming. How can you tell if they are WAV or FLAC?I believe all streaming is losslessly compressed.
It is bizarreSo bizarre. I assume that Emile and team have an explanation for this.
I assume we are all using the card with the switch so the basic conditions are the same. I also assume we all put the card in slot 2 where the old SPF card was.
Yes, I see it in finder on a Mac and then in Roon. Too much troubleYou would have to look at your drive in explorer. I don’t think XDMS gives you that information. Roon probably does if you tap on the star.
It might sound like we are complaining. Not the case. Just giving feedback so @Taiko understands what is going on out here, which they probably do, but we're making sure@Taiko Audio So without the bracket my Extreme was up and running for 5-6 days without any issue. Today, after installing the card with the new bracket I lost a connection between 90 and 120 minutes.
Bizarre.
It might sound like we are complaining. Not the case. Just giving feedback so @Taiko understands what is going on out here, which they probably do, but we're making sure![]()
