Ah, that sweet sound of glass and marble....sorry, I just could not resist...
You do not know before speaker placement you should not treat your room.Ah, that sweet sound of glass and marble....sorry, I just could not resist...
So, the proud presentation is just a work in progress, than? Looking forward to see the final result....at least the marble tiles are useful for moving things around...and for cleaning...'clean sound'....sounds like a great marketing slogan....You do not know before speaker placement you should not treat your room.
The most important thing is speaker placement, it takes time and effort
TAD design is far from marketing clean sound.So, the proud presentation is just a work in progress, than? Looking forward to see the final result....at least the marble tiles are useful for moving things around...and for cleaning...'clean sound'....sounds like a great marketing slogan....
that's an absurd statementTAD Labs has no rival in this industry at the price range
Dear @Amir IME glass is not the worst sounding material regarding acoustics. If they are well fitted on windows, dampened with rubber and thick enough they actually don’t do much harm. Marble floor is not the worst either. Maybe more carpeting helps but a well supported wooden floor is better.
IMHO the most problematic area in the picture of your listening room is drywall. Drywall is ultimately worse than glass and marble. I’m guessing the air vents on the ceiling constructed using drywall. It works like an additional driver ruining bass and midbass by adding reverberation, killing clarity. I hear you’re saying your system sounds great and clear but I’m sure it will sound better when you get rid of that drywall. I cannot explain how bad drywall is and how impossible to get rid of it’s negative effects. Concrete or brick walls and a concrete floor and ceiling is a must for a listening room. If desired they can be covered with wood afterwards but it must be supported/dampened not to resonate. Anybody thinks a drywalled room (all walls) sounds good or can be treated to sound good is wrong.
No, drywall can never be good cause it doesn't have the stiffness, rigidity, high specific weight that bricks and concrete has. It also has a very bad character of reflected sound.Properly used drywall in an excellent material for sound rooms.
Obviously, they’re not the best listening rooms. If they had put the same care and effort into building a listening room with brick or concrete instead of drywall, it would have been significantly better.In fact some of the best listening rooms we read about in high-end forums are drywalled rooms, as you call them.
I agree but there is a cure for it as long as it has been covered with stiff, rigid material like concrete and marble. There is no cure for drywall. I don't take into consideration of a person's evaluations about audio who is listening room is made out of drywall. I don't aim you or @Amir with this sentence. Actually I don't aim anybody. I just wanted to point out how bad a room covered with drywalls. That's my opinion.And from a purely subjective and personal perspective , listening in the shown space with such clean and empty aspect would create a negative listening bias in me.
No, drywall can never be good cause it doesn't have the stiffness, rigidity, high specific weight and it has a very bad character of reflected sound.
Obviously they're not the best listening rooms. If they had spent same care and effort to build a listening room using brick or concrete instead of drywall it would definitely be better.
I agree but there is a cure for it as long as it has been covered with stiff, rigid material like concrete and marble. there is no cure for drywall. I don't take into consideration of a person's evaluations about audio who is listening room is made out of drywall. I don't aim you or @Amir with this sentence. Actually I don't aim anybody. I just wanted to point out how bad a room covered with drywalls.
Do Acoustic Engineers recommend using drywall instead of bricks and concrete? Is there any proof of that? On what basis?Acousticians and scholars addressed these issues -
Is your listening room is made out of drywall?Thanks for telling us that you do not consider opinions of people who disagree with you. Nothing to add.
No, I don't ignore anybody. The problem with drywall is its reverberant character. Unlike heavy, stiff walls of concrete and bricks, thin drywall panels act like an additional driver due to its light weight. Covering it with absorbing material can only reduce reflections over the surface but cannot stop it moving like a driver.Again, it is not a black and white affair that can be summarized in a post - this is not the story of the three little pigs and a wolf. Usually sound rooms are a mix of techniques for engineering and sound reasons. The point is that we can have excellent rooms using drywall. The main reason is bass absorption, addressed in most books about the subject.
Yes, but not all of it. Feel free to discard my opinions. Are you putting on ignore anyone in this forum having vestiges of dry wall in his room?![]()
No, I don't ignore anybody. The problem with drywall is its reverberant character. Unlike heavy, stiff concrete walls and bricks thin drywall panels act like an additional driver due to its light weight. Covering it with absorbing material can only reduce reflections over the surface but cannot stop it moving like a driver.
A moving surface means it’s vibrating and producing sound. Try listening to your setup with additional speakers in the room—ones with large bass drivers but not connected to an amplifier. You’ll notice a smear in the sound due to vibrations produced by the unconnected speakers. The main speakers playing act as the source of these vibrations in the passive speakers. Same goes for drywall cause it is light, not as light as a cone of a driver but still light. Increased rigidity and weight of a concrete or brick wall compared to light drywall, it is more difficult to move it in audible frequency range by sound produced by speakers. This is about reverberation and resonance.The spectrum of audio is wide 20 - 20000Hz, materials have different properties depending on frequency. Remember drywall is associated with powerful absorbers, such as rock wool when used in acoustics.
The energy radiated by speakers must be absorbed - and a moving surface can be an indication of absorption in bass frequencies. Can we talk in terms of standing waves?
On the other hand standing waves are related with reflection.
Maybe you found a way to overcome those shortcomings of drywall but it is difficult. Just my two cents.
This definitely has not been my experience. This is the first time I have even heard of this claim.Drywall is ultimately worse than glass
I admire your confidence.I bet my room sounds better than yours and I have a mixture of drywall, stone, and wood.
And I admire the way you debate.Sorry it is not possible to debate anything using old myths and such basic empirical evidence. I did not find anything - I just used existing knowledge on acoustic room design and treatment.
If you are curious see how some rooms referred in this great old thread are built see :
https://www.whatsbestforum.com/threads/best-dedicated-listening-room-youve-ever-heard.30662/
If needed chatgpt will easily find additional information for you on these rooms.
You have not been around long enough...This definitely has not been my experience. This is the first time I have even heard of this claim.
